My Watchmaker uses only one oil !!!
By HectorLooi · Posted
I have been looking for this exact thread for days now! I love watchrepairtalk.com!! đ„° Thank you, thank all of you!
The white circle shows the expected radius of the âgolden curveâ. The red arrow points to where the hairspring is kinked most likely. Â
