I am aware brass mainplates and bridges get nickel + rhodium plated after finishing and decoration, but what is done with the wheels? I have seen a single source refer to this by saying the gear blanks are plated before tooth cutting, and a single video where they are plated after cutting (I'm fairly sure this approach is wrong, as the plating would come off the meshing surfaces and goop between the wheels.) No other watchmaking or repair resource I have found mentions the topic, but cannot imagine that Patek, for example, leaves their wheels untreated as they would tarnish. I have also seen a few movement manufacturers move on to using copper beryllium alloys for wheels instead of brass, but could not find any information whatsoever as to the specific alloy or finishing techniques used for that. Is there anyone here who could help clear this up for me?
I don't think they are ever plated, just machined from solid brass alloys, or gold etc.
See them being hand made :
I've just stripped and Omega 620, so the wheels are a coppery colour to match the mainplate and bridges. I assume it's a brass alloy with more copper in to get the colour.
Edited by mikepilk
Generally speaking they are plated except for very cheap movements. Ideally they are plated before cutting the teeth, but not always, and it's not really an issue except for barrel teeth where there's just a whole lot of power. Beryllium copper is used for some watch gearing, yes, but only where needed- it is closer to steel in general strength and wear resistance than copper. But it too needs plating or it can turn quite dark. It would often be seen in autowind components or in some cases even ratchet wheels.
On old watches, like over 100 years old, if you look around the union of the pinion and wheel, you will often see dark tarnished brass. Back then (in Switzerland at least), wheels were cut oversize, then mounted on their pinion. In some cases the teeth were simple saw gashes, or they could be roughly formed. They were fit up with the mating pinion in a depthing tool and finished to size in a topping or rounding up tool. Finally, they were plated- but the steel pinion would be protected with a lacquer, thus the dark area of brass right at the mounted pinion.
I wonder if they're gold plated then, as the color is closer to raw brass - I've never seen a rhodium plated/white going train, I don't think. And yes, neither Smith nor Daniels mention the subject at all, which is partly how I got confused in the first place. I'm sure if I could ask Smith he'd have an interesting answer.
I've not had the bridges off the 620 I have but if you look closely you might see a wheel or two. Not nearly as brilliant as the bridges.
Edited by grsnovi
Generally gold plated, could be rhodium or whatever. I worked on a bunch of Harry Winston Opus 7 pieces where the main wheel (3 wheel gear train) was blue. Inside of teeth not blue; those were expensive to make as there was a lot of beveling and graining to do before cutting the teeth- then cut the teeth without blemishing the finish.
Often dial side gearing like minute and hour wheel don't get plated, even on higher grade stuff.
Omega bridges plates and (sometimes) wheels were plated with a proprietary "recipe" for the copper color. I've read that tests have proven it's pure copper plate, but in my experience next to impossible to replicate with pure copper. But there are a LOT of variables in plating.
It's hard to tell from the pic with the way the light reflects, but they look the same colour to my eyes 😀
(and that's before cleaning)
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
