I'm currently 3D printing a new basket and trays for my Pearl machine - I printed one last week in PETG material and it worked well at first. I had taken a calibration cube and soaked it in old cleaning fluid for 8 weeks and then measured it, and there was no discernable swelling or shrinkage and the cube seemed mechanically intact. All went well after the cleaning cycles and then onto the drying cycle..... that's when things went awry. The heat was more than I was expecting and the basket and individual trays warped and deformed, I later found out that PETG is rated to 65°C working temperature (PLA = 54°C)
I am now trying to print from nylon (working temperature = +/- 100°C, depending on the specific blend) - but it is extremely difficult to print with, my third attempt is chugging away now while I am at work - hopefully I don't go home to a ball of wool like last time!
Assuming the heating compartment can't go higher than 100°C.... but not second guessing myself...anyone have any ideas or measured it?
I also have a question on the trays, maybe I'm not seeing the obvious, but how do you use the ones identified with the arrow? they are called
Basket_for_large_mainplate_and_mainspring.stl
Basket_for_small_mainplate_and_mainspring.stl
I can see the place for the mainplate, but how are you supposed to place the mainspring, you can't uncoil the mainspring to fit around the outer circumference of the tray or else you would damage the inner tight coils. Is the idea that you supposed to lay it on top of the mainplate?
Edited by Waggy
Neverenoughwatches.
I did read your experience with the basket. I did try to file mine to true it up..but I couldn't find the sweet spot.
I figured I would just bite the bullet and get the Elma components.
Thanks
Randy
4 hours ago, Randy55 said:
Neverenoughwatches.
Thanks
Randy
I could only improve it, its still not perfect, the slight bit of wobble left seems to add to the agitation.
you mean your improved 3D oscillation design upgrade
  • Haha 2
Yes exactly scott, i managed to make it run perfectly true and then reintroduced some calculated wobble using a special formula that i created myself .🙂
  • Haha 2
Is your special formula called Bovine Excrement ? Hehe.
  • 4 weeks later...
On 3/20/2023 at 6:10 AM, gpraceman said:
At some point, I would like to try an automated design.  Maybe repurpose a 3D printer.  For giggles, I was able to easily fit 3 mason jars and my drying station on my Ender 3's bed.  Mount a stirring motor to the X-Z axis gantry.  Maybe repurpose the hotend heater, thermocouple and fan to make a drying station.  3D printed brackets to hold the jars and drying station in place on the bed.  Arduino or Raspberry Pi to control it all.  Not sure if anyone is interested in collaborating on such a project.
Hi @gpraceman it's been a long time that you wrote this, but anyway. I have started to think about building a DIY cleaning machine and while thinking about the parts to use, I am thinking about reusing an Ender 3 3D printing machine and controlling the stepper motors with an ESP32. It's very early stage in my mind, but I wonder if you had done some progress in this direction ?
All the best.
Stephan
All the best.
Stephan
Sorry, hadn't made any progress on that project.  Had family issues come up and took time off from watchmaking.  Still using my budget machine based on a lab stirrer motor and a lazy susan turntable.
I fit the main plate in the tray first and then place (stuff is more like it) the mainspring on top.  The tray is tall enough to accommodate both.
Hello gpraceman I was thinking to buy a vintage cleaning machine until I saw you under budget cleaner machine, great idea, this has been my project for the past month. The only thing is I can't figure out how to make the drying station, I tried the heater but the wires gets too hot.
Looks like a good setup.  I like how you put the stirring motor post through the center of the turntable.
What's the specs for the heater you are using?  Specs for the power supply?  How long are you running the heater?
Edited by gpraceman
I order a dc 12v adapter converter and a 12v ptc heater. The connector circled in red is the one getting hot when connected for 1 minute and the heater fun for some reason blows more air towards the back then thru the coils.
The problem is likely the psu and cable are well underrated. 100W @12V is a bit over 8 amps, the psu and lead are designed for 5 amps
Tom
As Tom indicated, your power supply is not up to the task.  With 12V and 5A, that makes only 60W while the heater it is supplying is rated at 100W.  Try to find a power supply that provides at least 100W.  This is the one that I have, which is a 120W unit.  https://www.amazon.com/gp/product/B07PWZQ33N/
Anyway, I think 100W is way too much power for the heaters. I use a 50W 220V PTC heater and I find that already too powerful. I think the original heater was only 15W or 30W.
If the fan is not rotating in the correct direction, you have your fan leads swapped.  The air should be flowing through the heater element.
That is the other way that he can go.  Keep the power supply and try a PTC heater that needs less power.  The 100W ones are more common, but I do see at least one 50W heater on Amazon.
Edited by gpraceman
Thank you gpraceman and hectorlooi.
I will try again with the right volts and watts.
Thank you again for the info.
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently!
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
