Miniature carriage clock
Stuart2
1 hour ago, HectorLooi said:
If you remove all the carbon steel components of the balance cook, you could soak it in alum. It will take a couple of days.
the screw is actually screwed into a steel regulator arm, so I'm guessing that wouldn't work in this case.  I'm fascinated by the idea though, I've never heard of alum before now.
4 hours ago, oldhippy said:
If there is nothing to grip. How are you going to cut a slot. From the photo I can't see if it is protruding or not.
well I was thinking I could cut a small slot across the broken screw and the piece that its stuck in.  So long as the screwdriver is narrow enough I'm hoping it might be able to turn the screw.  As a backup, I might simply try and drill another hole in the hairspring stud and just leave the broken screw where it is.
It is possible to cut a slot, but the screw is so thin, that I wonder what will cut that thin slot. Then, will the screw untighten by the force of that small screwdriver if it was so tighten that it broke off? If You pres the stud out, then it will be easier, as the screw will be not tighten any more.
The standard way is to drill a hole thru the screw with smaller drill bit, to press tapered broach in and try to unscrew, and as a backup - to drill with bigger drill bit and cut new thread for bigger screw
Have you tried knocking the stud out? That might loosen the screw. You could also try some penetrating lube. A screw slotting file I expect it will be too big. One thing I used to use was an old watch oilier finding a rough part and try to unscrew it that way, It never worked all the time but you might like to give it ago.
thanks guys.  I did manage to press the stud out.  The stud is quite a tight fit still, so might simply try to press another stud in, positioning the hairspring hole at a suitable depth, then just leave the old screw where it is.  No real need to remove the screw I guess.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
