Trying to case an older movement is not easy, I know.  And the 620 from Omega seems to be a bit worse due to its slim design.  The movement I have is a round dial, 27.5mm.  Anyone have any ideas or locations I can find a case that fits?
  • 1 year later...
I am having the same issue with the same size dial, 27.5mm, cal 620.
Did you find some case numbers that would work?
Edited by EdsPen
