Hey,
I'm working on a Roamer watch with a ST-96 movement, and it has these shock springs that I never saw before and can't find anywhere online. They can turn but don't seem to have a tooth keeping it in place.
The dial was glued on so I spend a lot of time cleaning glue off everywhere on the movement, so I might be missing a little grove, but I really don't think so.
(picture from Cousins, found it in an assorted shock spring picture)
Though ST-96 is originally Swiss, you might have bought a deluxe Mumbi special.
Thats not a springy spring, just keeps the end stone put. Best to clean it in place.
Rgds
Rgds
Thanks Nucejoe!
Now that I look at it, it makes sense.
Thanks for saving me a lot of frustration!
Interesting...randomly I was looking at a movement I have that is in pieces (bought it that way) and it has similar shock spring.  It is an AS 1568 alarm movement.
Lousy image, but you can see the three tabs.  I can see no way to remove it.
I ended up pulling one out. I really don't know how, I was moving it around with an old oiler and it popped out. But now I can't see how to put it back in... 😆
  • Sad 1
 With one or two tabs slightly raised, end stone can be wiggled in the jewel housing.
Tabs when lowered back on end stones might not tightly secure end stones, try shaping the tabs curved ( concave down , convex up) so tabs push on end stones when lowered back on end stones.
Good luck pal
This looks like the shock system  Yoni's  watch has, but they might be different systems with different names and patent.
I think the spring on this one has some springness, whilst tabs on OP's watch  lack noticable springness.
Both best get cleaned in place, frustrating that one can't know ,how good of a shape the end stone or hole jewel underneath it is in, until you remove and check it. Flawed design indeed.
I guess TG is where you'd know if the jewels are faulty.
Rgds
Yep, classic Mumbai special 🥴
The FHF/ST 96 is commonly used as I believe it was made in India. It's commonly seen in fake watches, like Favre Leuba (this one also had the dial glued on)
