Hi guys,
im in the US and have a tag hauler acquaracer 500m professional  WAJ1110 with movement  eta 955.112
It currently have two problems
1) Crown rotates but dials will not turn. I also replaced the stem but didn’t fixed the issue,
which part its probably broken?
From which seller can I buy these parts?
is it possible to buy  the whole mechanism eta 955.112 and replace it and where?
2) its very hard to screw the crown down
Where can I buy crown and tube, I tried eBay sellers nowhere they sent me the wrong part
is there a place to see the exact part numbers for my watch?
thank you guys!
John
purchasing a new movement will have a couple of minor issues. such as the link below notice the reference to date at a specific location your date is in a different location. Worse case you have to just swap the calendar disc. Then there is a height issue which you can see by looking at the links below.
https://www.esslinger.com/eta-3-hand-quartz-watch-movement-955-112-date-at-3-00-overall-height-3-9mm/
https://www.esslinger.com/eta-3-hand-quartz-watch-movement-955-122-day-and-date-at-3-00-overall-height-4-3mm/
ct_955112_esi_491182_10.pdf
