Suggestions for Workbench layout
I am retired and have been learning watchmaking using my desk and a folding table....very bad but I wanted to be sure before I really dived in.  Will I dived in with buying more than the basics.  So I am committed.
I have an area in my office that is 12 feet wide that I am considering converting to the watch area.  I can add tables, built in, watch repair desk, whatever and am looking for suggestions on how best to lay this out.  For example do I build it all higher than a normal table?  Do I get a watch repair desk and put it in the middle with tables on both sides?  do I do a regular long table and get a table top watch repair piece?
I will be getting a microscope which is what has held me up in doing certain things.  I have a Boley F1 I am practicing on but that will remain in the basement because of the filings flying around.  I also have a L&R Master that I rebuilt to almost new and an ultrasonic that I will put in the new area I create.
Any thoughts and help is appreciated, even pics would be awesome.
Thanks,
Bob
bobolink
Jealousy. Jealousy. Oops, must stop singing. I have 5'x3' table in our study on which I have my stock draws, case holders, computer, printer and screen. Then I have my tweezer, screwdrivers and timegrapher. I use a plastic box to work in so that I can stop most pings'. My bride has the adjoining one for her craft which has her tools sewing machine and computer and screen. Oh! And the room is carpeted.
What, me jealous of your 12' wide area. Jealousy, jealousy. Must stop listening to Billy Fury.
Edited by rossjackson01
Mark has a weekly "Show us your bench" thread on the WRT Facebook page, you might want to check that out for some ideas. You may want to consider putting the L&R in the basement as well if you will be using solvent based cleaners depending on ventilation on both areas.
Edited by GuyMontag
If you have a window at a decent level in the room arrange your work bench to that. Don't have carpet on the floor, a light colour flooring is best. Make sure the walls are light in colour, Your bench need to be high so that you do not have to sit hunched over when repairing, an adjustable comfortable seat is a must. A good bench light make sure it doesn't cast a shadow over the work space. Try to arrange things such as tools around you so you do not have to keep getting up. Have something like wood beading around your bench to stop stuff from rolling off. You will need plenty of power sockets so try and keep the wiring out of the way. The more light you have the better. If you are going to clean watches/clocks in the room make sure you have good ventilation. This hopefully will help you. One last thing no matter how big your workshop is it will never be big enough.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
