Battery leaking Cartier Must
Is it a crystal or an acrylic and just foggy with age?
The point I missed to make !  is ; moisture in the movement is the main problem, it can ruin electronic components. Â
@VWatchie I believe that function to turn ads off is a Patron and moderator perk as they contribute to the site with money or time respectively.  Tom
By watchweasol · Posted
Hello and welcome to the forum the attached will help you . catalogueofwalth Watch Parts..pdf TZIllustratedGlossary.pdf -
Yes, now that you mention it, I think I remember (it was a very long time ago) creating a link for each picture, and that was massively time-consuming. I'll edit the post once I get the time for it. By the way, it's good to see you back on the forum! I have no idea how much the ads are bringing in, but I hope it’s at least enough to keep things running — and maybe even leave Mark a bit extra for stuff like food and rent. Not sure if everyone can do this, but you can actually turn off the ads. Just scroll down to the bottom of any page, click on "Theme," and pick one of the "No Ads" options.
