Eyup watch peeps , so i have a random question regarding storage. I seem to be aquiring a fair amount of watch material in particular balance staffs and stems amongst other bits and pieces. And in doing so am rapidly running out of space in the temporary watchroom. I have a few of the mini Ronda chests of draws that hold a little under 1000 calibers but am looking for small containers to load into them. Many joblots of staffs etc come in small plastic or tin tubs with lids finishing at 20mm + diameter but these are too large for the draws. Also used are two part acrylic capsules which would fit perfectly but i cant find these anywhere. Soooo i was thinking of empty medicine capsules, these can be bought cheaply in gelatine or a veggie version. Any thoughts as to why they shouldn't be used, only thing i was wondering was how quickly degradable they are and how moisture resistant.
My mentor just seals the part with a slip of paper with the description in a plastic bag. He has a sealer that seals and cuts at the same time. Then puts the little bag in small plastic boxes. Everything is labelled and organized.
While me, I keep turning the house upside down looking for things that I know I have, and end up finding things that I don't remember having. Then I get distracted and forget what I was looking for. Anyone else like me, raise your hand.
  • Like 9
Thanks Hector, thats given me the idea of vci anti corrorion paper.
How do you keep the stems etc. Do you keep each one in an individual bag?
I'm giving consideration to doing what you do, but the contents of each movement I will place into the plastic bag and label it. I use little plastic tubs at present, but they take up so much space in height. In a bag it will be lower and I can place more in the drawers. (I think)
Hi Ross . The post was about seperate acquisitions of joblots of staffs and stems and are to be stored in miniature chests of draws that Ronda supplied to watchmakers years ago. If storing a complete movement best to keep that as a whole as fully assembled as possible inc. the stem. Small zip lock bags are ideal for this and are cheap as chips So i would say a good storage solution for whole movements would be a 2x2 zip lock bag to keep moisture out and then stored in egg boxes that you could stack somewhere.
I agree and will do so. As a matter of interest, having many stems, how do you know which watch they are for?
I only got stems and parts for the watches and movements I own, so I have all part for each watch or movement documented with each. But, I do have a lot now, probably 50 watches and movements in total.
Edited by rossjackson01
grammar. spelling.
Most were bought already labelled. The stems and staffs i have that are unknown i measure them with a bench micrometer and check them with staff and stem lists. Balancestaff.com have a huge database of staffs and stems. After much practice it now takes around a minute to measure them and can take up to 5 minutes to find a calibre match on the data base. The stems require taking 6 dimensions and the staffs 5. The unknowns are like treasure hunting, interesting when i find something high end. Have recently pulled out VC, Blancpain, omega, Patek. My reason for aquiring large amounts of staff stock as most watches i was buying needed a replacement. I didnt want to be in a position of searching buying and waitng separately.
Edited by Neverenoughwatches
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
