Now that I have worked on a few watches, I have started to develop some "spare" parts watches.  I'm just curious, how do you all store these?  Most I have put together as complete as possible, but others have some pieces not in them (I just haven't put them back in) and are in parts trays.  I'd like to do something with all these, but I'm not sure if I should reassemble them, or if there is a good way to just keep how they are and not forget a) what it is and what watch it goes to, b) parts safe from damage.
One watch I put in a small zip lock bag with a piece of watch paper that has written on it what that movement is missing and then I placed that in my wooden tool box.  This concerns me though as nothing is protecting it (no, it's not in  case of anything... just a loose movement).  The pieces that are loose (hands, dial, hour wheel, and a few other small things) are in a small parts bag so they won't get into the movement.
Anyhow, what do you all do?
Coin envelopes with the movement written on the outside in alphabetical order. If it's just parts they go in an old tin fuse container and then in the envelope. I will write on the outside of the envelope whatever part I "harvest". I tend to put the movement back together if I have to take out a part(s).
Edited by GuyMontag
9 minutes ago, spectre6000 said:
I use these for loose movements. I keep needing to remember to order more, as they come in handy for many watchmaking things.
https://www.cousinsuk.com/product/aluminium-pots-in-aluminium-box
For cased movements, I have a small cardboard box with a nice closure with a colorfully worded label.
Those look pretty nifty, I like the glass tops so you can see what's inside. And they are surprisingly cheap!
Any watches i have that are beyond repair at the moment are stored fully assembled in mini zip lock bags and then placed in egg boxes. By being assembled they are protected attached to the calibre that they belong to also providing a premade up walkthrough if needed ( trust me you will forget the assembly order over time ). The zip lock bags offers a moisure barrier, the egg boxes gives further protection keeping them seperate  and are easily stacked. You could also chuck a silica gel sachet in the box if you felt like it.
On 5/9/2023 at 4:51 PM, kd8tzc said:
That's a great idea (and inexpensive) for the coin envelopes.
Keep in mind the environment in which you live. Here in the Uk people are struggling to keep their houses dry and warm due to ridiculous energy costs. In winter older housing structures can be cold and damp without constant heat. Plastic bags are a permanent moisure barrier, regular paper is hygroscopic. VCI paper is a good alternative with good anti moisture properties.
    • I recently repaired this movement but the screw for the ratchet wheel was the wrong size and it was bugging me (pic 1). I tried to find a replacement but I couldn't match the head width and tap size, so I decided to make one.  I wasn't sure of the tap size for the screw, but it looked to be either 1.0 or 1.2 so I made a test screw out of a brass bar, with a matching threaded hole on the other end. I didn't photograph this but you can see the bar in picture 4. I settled on a size and proceeded to cut a steel bar down to length. I softened the bar first to make it easier to work with and the cut it to size, using the chart on my tap and die set for reference Once cut I set up the die in its holder and used my tailstock to hold it straight while I created the thread. Once the thread was cut, I tested it using the brass bar Happy with the diameter and thread I cut the screw off the bar and then twisted it into the bras bar to use it as a holder,  for securing it in the lathe to protect the thread I made a face cut to clean the head up Next step was to make the slot. I currently do not have a table saw for the lathe so I was going to have to use a saw. To keep the cut straight and centred, I made a jig out of a piece of brass bar by drilling a hole big enough to slot over the stew, with a slot in it to guide the saw while cutting the slot on the screw head I then cut the slot with a fine saw (I forget what they're called, pin saw?). Once that was done, it was ready for hardening and tempering and then a first polish from 800 grits to 2000 on the lathe. The picture below is just before the first polish. Once I got it to polished with 2000 grit, I removed it from the lathe and then polished it with diamond paste and a Dremel, using the brass bar to hold it. (this turned out to be a really useful tool) Finally, it was ready to go into the movement. I am pleased with the result. I should have made it flatter to match the crown wheel screw better but, overall, it is a vast improvement on the screw that was in there. The main thing I took away from this was how useful the brass bar was, not just for testing the thread but as a holder in the lathe, for cutting the slot and for handling when polishing. No trying to hold it with tweezers or a vice. It was a really simple tool to make and really worth the 10 minuets or so to make it and cut the threads. The slot guide was a huge bonus because it worked much better than expected.
    • I finished a couple of pinions I started yesterday, read up on Breguet hairsprings, made a balance staff, fixed my tool and cutter grinder, and in between checked in here. Having a (2rd) pint with the missus now 😍.
    • I must update myself, I guess nowadays the lubrication procedures and assembly protocols have improved or, at least, changed.  I hope there is still hope for vintage tools in this area.
    • Lol ok, well I'm not about to explain it, I'm a bit fuzzy on it myself, I'll get it all arse about face.....actually that might be part of it, now I come to think about it.
