Fitting 7750 hands on a 28XX - 2mm OD - 1.5mm ID / 1.2mm OD - 0.9mm ID tubes available?
Super excited to share that yet another Rolex has landed on my bench — this time a Sea-Dweller, ref. 16600, equipped with the trusty calibre 3135, same as the last one I worked on. It seems to be running smoothly, although I haven't measured it on my TMs (PCTM/Weishi 1900) yet, but the time and date settings are completely dead. My first thought is that the yoke has slipped out of engagement with the sliding pinion. It could also be something else, of course! Haven’t had a chance to crack it open yet, but I’m itching to take a closer look sometime next week. Anyone else seen similar issues on the 3135? Would love to hear your thoughts before I dive in! 😉
Have a look here at what parts differ from the 7J & 17J https://www.emmywatch.com/db/movement/caravelle--11do/ There's also this. Bulova Interchangeable Parts Catalog.pdf
By SwissSeiko · Posted
yes 316 stainless is what they used on these bezels. Maybe some of THESE would work, otherwise, get a 2" round bar, and turn it to your dimentions -
Books, or some sort of voucher to a material house if they do them. You can never read and learn enough and if you find a material house that could do a gift card then the person could pick things they really need. Tom
