All,
I made an adapter so I can use my old threaded dies in my new Robur press and thought I would share.
image.png.2009513d6210605a2054f5b036b704d7.pngimage.png.9acc395d2911f78b38e390ea20361522.png
You will need to push in a standard M6 bolt from the bottom and have the thread sticking out the top - I found a 12mm long bolt seems to work for my old threaded dies. Mine went in the bottom with a push fit and stayed in place with friction alone, but you could secure with adhesive if your bolt does not stay in securely with friction.
Here is the link for the Thingiverse files for the above threaded die to Robur press adapter
Below is the Robur press die to threaded press adapter (same link)
Enjoy!
Hello community and thanks @Waggy!!
A friend kindly printed your model and I'd say it works perfectly. I used a hammer to beat in the bolt and it holds nice and strong, just by friction. And well, when you screw it into a die, it actually reinforces the hold.
You are right, 14mm length is better. I got 12mm and that works just find for flat dies and larger convex dies. However, for smaller convex dies (if they are also convex on the backside), the bolt will not reach the thread.
20230714_184612.thumb.jpg.0196fb5c81d834baf8ef2e523ae9b972.jpg20230714_184617.thumb.jpg.76ba25135b8be955f518b7b261c51100.jpg20230714_184638.thumb.jpg.f1dfc4c406f3b7df83f629640f2be712.jpg
  • Similar Content
    • Update!  I've dismantled it, cleaned all the glue off, and rebuilt and lubricated the base movement. I'll leave the chrono part for another day. It's running well - great amplitude and keeping time, but it's got a beat error of 4.8ms.    How important is it to correct this? I'm worried that the potential for making things worse having to take the hairspring off and on repeatedly to adjust this. Would anyone here accept it at that?
    • Since I've been banned from the previous discussion, apparently my language was inappropriate...for small boys. I will start another thread and act in a more decent manner for the girls and ladies of the group.  Please what will happen if the forum can't be managed by the administrator, are there provisions in place to preserve the achived member's questions and answers over the years. Please if I may ask these important questions that are important to the members please.
