Hello everyone,
I'm trying to restore my father's old Seiko 2260-5510 quartz. I'm not really skilled on Seiko and I'm not able to find any info on bezel and case-back gaskets (they are shaped). They really need to be substituted.
Where can I find parts numbers? Are there any catalogue online?
Are there any non-Seiko equivalents if original parts are not available?
Thank you very very much in advance.
Regards.
You can look for case parts on Cousins, but they don't list any for your movement. Neither do the Jules Borel database.
Cousins have a page for Seiko gaskets, but you need to know the Seiko part number
https://www.cousinsuk.com/category/seiko-gaskets-list
For the case back gaskets, I measure and buy generic.
Here is a link to some very useful Seiko case info :
https://www.watchrepairtalk.com/topic/13897-seiko-casing-parts-guide/
Edited by mikepilk
Pictures are nice so we know what you're talking about
Then the problem with the various places where were looking is Seiko parts can be region located. So in other words Seiko watches that were not distributed out of Japan will typically not have parts available anywhere else.
Thank you for your reply.  I've attached some pictures.
The watch was bought here in Italy so I hope that some spare parts are still available somewhere outside Japan!
Thanks.
Thank you very much, great material at that link!
I'll go for generics for case back.
For the bezel I think I'll directly glue it to the case with hypo cement.
A little bit scared of separating glass from bezel... Maybe I won't find another gasket of present? Or is it glued? 😅
Thank you again.
Could you turn the crystal over so we could see the other side.
Then sometimes with the gaskets and I just can't tell with this one sometimes the gaskets are actually Rowlands and they just fit into the groove are not actually shaped but this one I'm just not sure about
that it also be nice to see the back of the watch case
Thanks.
Thank you again.
Thanks.
Thank you again.
Hi , I may have original new parts for this watch , just let me know the specific parts you need and i will check for you ,also in case i dont have some part i will help you to locate it .
Thanks.
Thank you again.
Same picture for the other side with the model details will be help , Any chance you got wrong with the 2260 calibre number ?
You are right, searched other sites with correct Hattori case number but here written wrong one! It's 2620-5510! 🤦‍♂️
Thank you for your help, I don't have original gaskets, but will go with generics if not available...
Well , I also searched and had no results 🙂
I think find an genuine gasket for this model will be hard ,as for the crystal and other parts there is much more chances , let me know if you after some thing so i will try to help .
Those old quartz models are truly great devices , i love them .
Thank you very much for your support!
I'll try to use generic gaskets for now and let you know!
Regards.
19 hours ago, EpsilonLyrae said:
2620-5510
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=SEK+CS%232620-5510&submit=Search
It's amazing what happens if you have the right part number. See go to the link above and you get parts numbers like Crystal which they don't have it all apparently but if you Google the crystal number here is supposedly one
https://www.stsupply.com/sa9n99kn00-seiko-crystal.html
Second link here looks more promising because it's basically taking you to eBay where you can go directly yourself I just haven't quite got there yet
https://www.emmywatch.com/db/part/crystal_x--sa9n99kn00/
http://www.julesborel.com/s.nl/it.A/id.22518/.f
https://gleave.london/glass-seiko-sa9n99kn00/
So basically go the first link click on the items you want get the part number in search online although they do have the gasket. Looks like Crystal may be in its Leon eBay. Otherwise the UK company looks like they have it probably others have it on not go to spend a lot of time looking I forgot that you had updated the case number
Thank you very much!!
  • Similar Content
    • Did you just swear at me matey?? I’m sorry, I’m not divulging personal information but there’s always personal reasons. There’s not much more than I can do other than plod along as best I can. However, my health is good now and I’m regularly getting plenty of exercise to keep it that way 👍 You know what. The ads don’t even cover a small percentage of what it costs to serve this site. I find most of it personally. If there are complaints then so be it. I do my best.  in fact - I have zero issues turning them off. Would that make the complainers happy?
    • Same question that was asked last time Hakan, and emphasis was placed on it. It was ignored. The thread should still be there, if not I have a copy of his reply.
    • This is probably the single most important point. One of my best friends, 48 years old at the time, suffered a massive stroke about 15 years ago. He barely survived, but his life was never the same after that. If you had asked me back then to guess which of my friends might have a stroke and nearly die, he would have been the very last one I'd have picked. He was perfectly healthy, played tennis three times a week, ran a successful business, was full of life, and had a wonderful wife and well-behaved teenage kids. The harsh truth is, we never know when it’s "game over." @Mark, I truly wish you a long, happy, and successful life. But have you given any thought to some kind of backup plan for WRT in case the worst should happen? Is there anyone who could keep the site going? If you can reassure us in some way, it would mean more than a lot to us!
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
