A bit  superficial in places but a pretty neat insight into how a modern watch factiry operates. I love the machine for simulating dropping the watch.
<iframe width="560" height="315" src="https://www.youtube.com/embed/hIiGRKbEHIE" frameborder="0" allowfullscreen></iframe>
Actually a very informative video. I especially like the way the unfinished movement is passed from one working station to the other: under the desks in a movable strip that stops at each desk and pushes the movement at work's height to be processed, then lowers the movement to bring it to the next station... Excellent planning of a chain assembly line!
Thanks Delroyb. Didn't know Breitling made their own movements - thought they used ETA
Wonder if you end up going completely mad putting bracelets together all day long...
I couldn't believe the that nobody wore hair covering in the clean areas, but I was well impressed with the machine punching out the case blanks from what looked like 1/2" stainless steel bar!
Brilliant film, it just makes me want one more, my favourite one is the 806 from the sixties,I would love one of them, but have to save my pennies,:)
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
    • I bought an old Bergeon 5555. The bottom of the tank was full of petrified salts, which also corroded the metal parts a bit. I would use just distilled water.
