Hi,
Just wandering what you think is acceptable on positional errors in old watches. Where do you draw the line?
Shoot!
Men
from an amateur point of view, a minute is the limit. 30 sec is confortable , 20 sec is great. Beyond that it is impressive.
I'm not a professional but use the Omega requirements for a 565 for any non chronometer movement. I can show you a COSC spec if you're interested in that as well. Here's a sheet I print and use.
post-1328-0-30106000-1438882433_thumb.jp
These are not known for brilliant amplitude but this is not bad. I usually test all six positions but for some reason, I didn't here. I was happy enough. These are only tested in these three positions anyway. COSC in five and 12H only used for you.
You should test at full wind (0H) and one day later (24H). Obviously, don't wear it if its an auto! For the 0H, I usually fully wind and leave it for 30 minutes before testing. As matabog said, basically thirty seconds is within spec. This one is so far in it would likely meet COSC spec. Lift angle and power reserve are calibre specific but the rest are good usable values in my opinion for a lever escapement. Target rate is +8 for these but I usually set them a bit slower and check after use.
Hope this helps, Chris
For me 30 sec. is not acceptable. Personally I always aim for +8 sec which is often a challenge in very old watches and If you want to stay commercial on the good side.
It sounds like you are a professional? I'm new here so are not sure who is who. I had assumed you were an amateur and didn't want to be too discouraging.
Are you saying that you aim for an 8 second variation across 5 positions on any watch? So, for something like an Omega 565, it is possible to get there. But a cheap fifties/sixties movement? I'm not being argumentative just trying to make sense of what you are saying. Even if you're using everything including dynamic balancing surely you're limited by the basic quality?
Perhaps you could give us some more information?
Cheers, Chris
In my opinion it ultimately depends the condition of the movement and what damaged parts you can replace/repair. The more you can, the better delta you will achieve.
For example, balance staff, cap jewels, mainspring obviously, pallet fork jewels, wheels, just to put a few out there.
If all can be replaced or repaired then then the original manufacture tolerances can be met and sometimes surpassed, temporarily.
Simply put, vintage: 20 sec 0H 30 sec 24H, 6 positions, daily rate between +1 to +10 seconds.
Modern watches stick to the tech docs and stay within spec but mostly under 10 second delta 6 positions at 0H and 24H and daily rate +2 to +6 seconds, that's acceptable to me!
Through watchmaking I restore connections in people's lives!
This is exactly my point. Not getting the parts where do you stop... where do you draw the line in vintage going back to the customer presenting a huge bill because of time consuming parts creation are declare it acceptable because no parts are available to get the +1 - +10.
I think it's up to the customer and what they want, sometimes it's enough that the watch just ticks and that's a quick enough fix that leaves everyone satisfied, the challenging ones are when someone has an unreasonable request and them some education is necessary
    • Hi all - I was just watching Clickspring's series making a custom faceplate and he demonstrates the "wobble stick" technique for centering. I  was already familiar with this and it is all straightforward. But how does one set the height of the T rest so that it acts as a truly level fulcrum? Or does it actually matter if the fulcrum is perfectly level with the hole you're trying to center? As I type this I'm realizing there should not be any motion at the other end of the stick even if it is at an angle relative to the work, and isn't pointing even with the tailstock center. Do I have that right?
    • Hi Can this pusher screw be straight again and how?
    • Typically watch manufacturing companies will purchase parts to their exact specifications including the jewels. This means that typically you may not find an exact generic replacement. I'm attaching a PDF of a book that explains how to replace jewels. Seitz book.pdf
    • Hey everyone! I sure this topic has probably been discussed before, but I want some good recommendations based on experience or knowledge about a good affordable high torque DC motor that I can use for my lathe. I have a little lathe but it has the regular old style motor that was used in the past with a foot controller. However, I would like to improve it by buy a nice motor with a speed controller so I don’t have to use my foot. I would like the motor to have really good torque so that even if I run it at a very low speed, it still can cut material easily. I saw online this brand called Servo sewing machine motor with a speed controller, but I don’t know how good they are and if they would work like I would like to for my lathe. Thank you for all the help!
    • Your only partially correct here. Let's look at a magnified view of the image up above. Then for a flat hairspring to function correctly there has to be a little bit of breathing room unfortunately. If you would like Better timekeeping if you get a watch with the over coil hairspring then those regulator pins are supposed to be as tight as possible but still allow the hairspring the slide. With if the pins are opened up at all you'll see a dramatic timing change based on amplitude. So in our example down below initially hairspring is basically free-floating not touching anything the effective length of the hairspring is at the stud. As the amplitude picks up at some point in time they hairspring will just tide should one pin on one swing and the other pin on the other swing. As soon as it does that it changes the effective length to being closer to the regulator pins. As the amplitude picks up more and more it's obviously touching the regulator pins more and more and the length of the hairspring shortens the watch speeds up. This is where in your video at around 16 minutes he opens up the regulator pins and the watch slows down. This is because they hairspring is no longer bouncing off either pin as much. Then because the watches running slow he speeds it up just to show that yes you could regulate the watch but now you have a problem. Because the regulator pins are much farther apart amplitude is going to have a much greater effect. Like in the image down below they hairspring is properly spaced between the pins. But if those pins are farther apart the effect of amplitude will be much greater. So he speeds up the watch to cancel out the effect of the regulator pins at the particular amplitude which was dial down then when he moves the watch to a crown position which will always have an amplitude decrease because the amount of friction on the sides of the pins now the hairspring is not touching the regulator pins as much and the watch dramatically slows down.   Let's look at the other example image. In this particular example they hairspring is actually touching the regulator pin at restWhich means the effective length of the hairspring is at the regulator pin the watch runs fast. As the amplitude picks up hairspring will lift off the PN moving the effective length towards the stud which is why the watches slowing down. As you can see is the amplitude picks up They hairspring is not centered C not getting even timekeeping and the watch is slowing even more down. But at some point in time when the amplitude gets high enough this will depend upon the watch the spacing Excedrin whatever the amplitude is will be balancing actually between the pins in the watch will of course speed up and then at some point time you reach that sweet spot where it's bouncing between the two pins but as you can see it's at a much higher amplitude. So this is why hairspring has to be properly centered between the pins and the pins have to be at the right spacing otherwise you going to get strange timekeeping based on amplitude which no matter what you're going to get a little bit of that as you do have to have a little bit a spacing. At least on a flat hairspring.
