Identifying a movement?
Martyn58
Hi everyone! My first post so please bear with me if I do something ‘wrong’.
I’ve been asked to have a look at my father in law’s Westminster chimes mantle clock which hasn’t been run for some decades.
Can anyone help me identify the movement? Maker?
Thanks in advance!!
Martyn
I cant see the whole of the stamp by the number 12 bottom right, I can only see Made in, so can you tell me? A stab in the dark if it is made in England then as the barrels are detachable I would say it could be a Garrard. Is there any I D on the dial? What is the case like?
Thanks for the reply. There’s no id on the dial. I’ll upload a photo. I’m in the UK so English might be the most likely origin. I don’t see the ‘Made in …’ stamp that you’re seeing so I’ll take a close up photo in the morning and upload it.
Ha Ha Ha it must of been me seeing things that are not there, that's old age for you. The case is in the design as what is know as a napoleon hat. The clock hands are in the style called serpentine. Now I have spent more time looking at the movement I think it is German, so it was made before the WW2 I would date this to be around the the late 1920's to middle 1930's
What do you intend to do? Are you thinking of taking the movement apart and cleaning it. It is complicated if its your first repair. You need to start on a timepiece or at least a strike.
Good morning! Thanks for the info. Well, for sure it needs disassembly and cleaning … parts have far too much oil and it’s grimy. I’m able to do a basic service of an Enfield strike … all except removing the mainsprings. I’ve also ‘learned’ the ETA 6497 pocket watch movement and a Seiko NH35 … so it’s not exactly my first project. But I’m anxious. That’s why I was hoping to find some information.
I think my main worry is : might there be particular alignment of parts to ensure correct quarters chiming?  Or can the mechanism sort itself out?
And you’ve prompted another question : are you saying that the barrels can be removed without separating the plates?
With all the other movements that I ‘worked on’ before I had a duplicate donor movement for reference, and YT videos. With this I have nothing so it’s a bit daunting.
Thanks in advance for your time, and to anyone else who pitches in.
Yes all three barrels can be removed with out taking the movement apart, make sure you let all three springs down first. The train on the strike side and chime side have to all be it the correct position to work properly.  As you have knowledge of a Smith's Enfield strike, the strike on this movement will be much the same to you.
Thanks for the info re barrels … I’m waiting for file handles to arrive to make a dedicated letdown key. I’m also getting closer to making my own spring winder. Wws.
I’m not a quick worker … I’m in no hurry … so will spend some time just observing the running movement before I do anything. I guess I’m also anxious about getting the plates back together with more than 15 mobiles inside … remembering my experience with a Smiths pocket watch which only has a handful 🙂
Hi this clock will have the auto correct pawls on it which means that when the hands are set by hand the chimes get out of sync and re sync at the hour, these can be a pest to get right so suggest you read up on it as there are quite a few simultaneous actins take place.
Barrels are fully let down … I’ll have a go at removing one tomorrow. But a rookie question about which clock plate to remove. On a Smiths it’s obvious but on this movement there are removable nuts on the under dial side. Removing those will allow the lugs ( for screwing movement into case ) to fall out of position. The back plate is held with screws. So nuts or screws?  Is there a convention as to which plate is lifted off?
Thanks in advance!
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
