Dear all,
I hope this finds you well.
I have the attached watch and was wondering what the scribes/etchings, were intended for.
Could they be to ensure both parts are a pair?
Could it be to show that the gold is not plated?
Wondered what the real reason is as I am only able to guess.
Any help on the subject would be gratefully received.
All the best, Steven.
Regarding the attached picture. This comprises of two images.
Image 1 - shows the upturned face, the etchings to which I refer are at the 12:00 position when viewing the image but at the 6:30 position once the face is attached to the body.
Image 2 - shows the watch with the face removed. The etchings are at the 6:30 position.
Many thanks for taking the time to look/respond to this query.
I would say it proves that both parts belong to each other. Don't forget some cases were mass produced. This if probably a factory assembly mark.
    • Thanks Mark. I think I’ll leave the beat error for now - it’s a fixed stud so I’d have to adjust the collet position.    The watch has bigger problems. On reassembly I’ve found that the hour counter reset hammer is broken - I didn’t do it, the main hammer part was just not there. Can’t easily identify a replacement part. And the subdial hands. The running seconds hand needs an extended pivot tube as the pivot is below dial level. Can’t find one of them either. I’ve found a central seconds hand that might fit it - going to have a go at cutting, filing and polishing it to make it work.
    • Good morning. I have a Caliber 11DO 17 Jewel that I utterly destroyed practicing on. My question is this. Are the 17j and 7j compatible in relation to swapping out parts such as the Wheel Train and Balance? Thank you in advance.
    • Ah ok thanks , i see thing differently now. Won't that catch the wheel rim though ?
    • No Mark it does not offend me. I think I have already started another thread on the matter before you replied. But since you are unwilling to discuss it with us, I will discontinue posting there.  Thank you for considering it though. That's a good policy to have H , you should always safeguard yourself. Knowing who you can trust and who you can't is not a permanent thing. People's values change, people change and adapt to their situations,thats just nature stepping in and running the show. Not everyone is as genuine as you are H. The new no advertising looks much better, it never bothered me much, but it still feels cleaner.  I'm pleased that your thread regarding the missing images was also returned, so thats good news as well. It appears a lot of mine have also been removed ...oh well...🤷‍♂️
    • Welcome to the forum. My guess would be to press or lift here.
