Calipers/micrometer?
24 minutes ago, RichardHarris123 said:
A few questions about calipers/ micrometers.  Do you own both and use them for different tasks?  Do you prefer Vernier scale or digital? Is there a big difference in quality between manufacturers, if so what do you use?
Yes yes yes and yes 🙂
Is it time to answer sensibly yet ?
19 minutes ago, tomh207 said:
Callipers are fine for “rough “ work, micrometer is better for finer accuracy but for pivot and jewels you need something like a JKA feintaster. Different levels of accuracy and fine measurement.
Tom
Thanks for answering sensibly Tom, you took the words from my mouth. I will add that i do have a cheap digital vernier gauge that is very accurate ( maybe i was just lucky ) that i use to take a particular measurement from a balance staff.
5 minutes ago, RichardHarris123 said:
Yes.
Are you sure ? Its a risky idea you have there Richard 🙂
I'm no wimp, give it your best.
I use Mitutoyo digital calipers for large stuff, where I don't mind being off +- a hundredth of a mm. When I need to split hundredths, it's a micrometer. I prefer non-digital ones as they are lighter and more compact, I find digitals cumbersome. Then there's an array of bench mics, with various shaped spindles and anvils, horizontal and vertical, and some indicating bench mics that will reliably measure to microns. Large mics for diameters up to 75mm, internal mics, I think there's at least a couple dozen around the shop haha. But a good caliper and regular 0-25mm mic covers most everything. Digital or vernier is a matter of choice.
Mitutoyo for digital calipers are by far the best on the market, mine are over 20 years old and run at least a couple years on a battery (I never turn them off), and check out spot-on on gage blocks like when they were new.
I use the Bergeon (the one on the left) when on the bench and need a basic measurement.
I use the JKA (center) when measuring a staff (or wheel pivots, etc.) and willing to go to the extra effort of fetching it and opening it up.  It consumes bench space, so I use it only when its features are necessary.
I use the caliper on the right when working on my lathe.
I used a Mutitoyo digital caliper (not shown) for crystals, stems, crowns, etc.
BTW, I picked the Bergeon for $47 plus shipping and tax on ebay.  It was a steal.
Edited by LittleWatchShop
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
