I was watching a video on YouTube and they were replacing a broken dial foot.  After setting in the replacement they used some sort of hand milling tool with a hollow center to cut away the excess dried epoxy and make sure that nothing was protruding above the base of the dial foot.  I have the milling tool to cut the recess into the dial and have used it a few times without much issue, but I thought this was a handy little tool to do a bit of extra cleanup on the repair afterwards.  I've used a very thin razor to cut away excess epoxy in the past, but I'd like to locate one of these if possible.  Would anyone know where to source one?  Thank you.
I think they are a horotec tool
Mark has a set, he might reply with the correct code number
Edited by Paul80
8 hours ago, thor447 said:
Thanks a bunch.  I completely missed that thread.
I'm not sure if John suggested it but using a pin vice with sharp jaws can work. It might be possible to put an edge on the jaws. I'm about to try on a cheap sliding collar pin vise.
That's a pretty good idea.  I'll give that a try on my next one.  I've been able to use a razor blade under a microscope to get the job done, but it is tedious work.
  • 11 months later...
Ok I bought a load of useless horse shit from Japan just to get a couple of crystal press dies that were included (Seiko S-150). Some pliers, hammers etc not all watch related. Some advice is still needed.
Some whetstone I guess. Very smooth surface. Some kind of little staking block. Cylinder full of very small punches? Watch included for scale purposes. Do such small staking sets exist? The one on the left is strange, some kind of cutter? The seller didn't know much about these.
10 minutes ago, RichardHarris123 said:
I think it is a stem cutter, if you don't want it, use the words Vintage and Stem cutter, you'll get a fortune on ebay.
Don’t forget “rare and Unique “ 😂 I seem to remember it mentioned somewhere that this style of tool was a factory tool to facilitate rapid trimming of stems in a batch.
Tom
  • Haha 3
Might be a bench braclet cutter, i have a hand one. @oldhippy i feel will know for sure what this is.
Did a quick ebay search, the bracelet cutter looks promising
Just now, oldhippy said:
Sorry I do not know. It looks to heavy and clumbersom to be a stem cutter.
Definitely some kind of guillotine, for cutting  pins OH ?  Might not be watch related but the new one looks similar and I've seen vintage ones that almost match up.
Obviously its completely useless so i think the OP should send it my way and i will dispose of it responsibly .
Ok. I did a brave thing and checked the apparatus from all sides. Turns out it is a watch tool, Gem pat no 435111, a bracelet cutter indeed. Thanks for all the guesses. I really don't see how it works and to be honest I don't really care. I like how it looks so I'll stick with it. IMG_20240626_202538.thumb.jpg.c1002cbb940e64d405f986d60ff98522.jpg
Yey i win , they dont call me Tommy the tool tinkerer for nofin,  I'll pm my address, how soon can i expect it to arrive ? 🙂
Haha, just realised my mistake 🤦‍♂️
Think Rich think before you press submit reply  😖
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
