Just a quick announcement that I have installed the Tapatalk plugin into this website. So if you are a Tapatalk user then you can now connect.
You can learn more about Tapatalk for iPhone, Android or Windows phone here.
I,m afraid my mobile is an old Moto which thinks an android is R2D2 and would only know a window if it fell through it.
Is that the one you had to wind up to make a call?  :thumbsu:
I've only had it for nearly 10 years and so have not yet figured out how to do everything,  it might be wind up for all I know.  I'm ok with the PC and can sort most things out with it,  but the mobile, forget it.
 LOL! A mechanical mobile - presumably with a Landeron 48 movement in it...
  • 10 months later...
I have to be honest, although TT is on my iPad i have more or less reverted to the Internet version. TT was getting a bit fancy navigating around our forum. I gave it a good try but got frustrated a few times probably because they keep changing the format and feed method. Really I suppose that this is just me not learning new tricks. Either way the option is always there if it is needed which has to be a good thing for those who have got to grips with it.
Cheers, Vic
Cheers, Vic
The trick is to ALWAYS read the ratings of the update BEFORE upgrading your current working version [emoji6]
Mine is still 3 or 4 versions old and it will stay that way.
I have to say - for me Tapatalk is quite frustrating. Every time they update it, they keep changing things around. It took me nearly 5 minutes to work out where a particular section was on another forum I use the other day. The old way was so much easier.
I tried it and removed it...it is frustrating enough for me to deal with my promotional US$1 LG tablet when at work...I guess you get what you pay for!
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
