I just acquired a vintage Elgin wrist watch, it`s an automatic with a waterproof case, and I need to open the case to inspect the movement. Got out my case wrench and started to try to unscrew the back, and it will not budge. It actually sheared off the corners of the inserts for the wrench! Does anyone have any suggestions for opening a waterproof case back like this? I've opened cases that were stubborn to get started, to change batteries, before but this is just not moving at all... Help, please?
I don't know what sort/brand of caseback wrench you have, but a decent Jaxa style with the correct bits should work.
Apply some drops of penetrant oil around the thread seam and wait for a day or two.
Fix the case in a case holder mounted or clamped to a bench.
Use a proper caseback wrench fitted with the correct bits, hold it correctly and apply torque.
Good luck with it.
Thanks everyone! I didn't know if I could use a penetrating oil safely on a watch or not, I know I've had good results with that with some gunsmithing I've done. I'll order a new Jaxa wrench and give that a go.
When I prescribed drops of penetrating oil, I mean't watchmaker sized drops, not locomotive engineer drops.
Put a bit of oil into a small container (egg cup, teaspoon etc) and use a safety pin dipped in the oil to apply the drops to six points around the caseback.
The oil will wick along the threads and shouldn't actually seep into the case if done in moderation.
I know you might think I'm stupid but are you sure it's a screw on back and not one of those imitation looking ones when all it needs is a case knife.
Heat is my friend. I had a seamaster case that i could move the caseback on. I applied some heat with a small propan burner. Just so much that the old o-ring let go. Inside was the gooye o-ring. That was the trouble.
Thank you JimInOz, I figured it couldn't be a lot, last thing you'd want is that getting into the movement. I'll give it a try as soon as the new wrench arrives. To answer oldhippy`s question unfortunately I'm quite sure, it`s not a case of spinning but not coming off it`s just not budging at all. Thanks again to everyone for all your advice. I'll be certain to get some pictures and post the final solution. This definitely gives me a great start.
Just a quick update.  Tried using some penetrating oil, let it set in the last couple days, adding two applications.  The new Jaxa wrench arrived today and still no luck.  Moving on to the more drastic bolt approach.
And, now I'm starting to think some joker screwed on the back with red Locktite, the bolt and superglue method failed me too.  I hate to do this, but I think I'm going to need to bring it into a shop just to have the back taken off.
This is also a possibility, or it might be a front loader. Please post some good quality close up photos, someone my recognise it and give you the correct answer.
Oh-my,
I just ran into this with a Jacques Lemans 1215.  Felt like such a dope struggling to turn for 10 minutes  :pulling-hair-out:  got super frustrated.  Had a lovely homebrewed saison after I realized the mistake and opened it with my case knife in 3 seconds!
Dan B
Excellent advice Dan, if all else fails...........have a beer! :)
I looked with my 5x loupe and saw the grove for a case knife- it was a good beer!  honestly- I did at least 5 very hard turns with the jaxa tool before taking the break and looking with the loupe.
9eb62d94ad67e3c73bda928ae85d1212.jpg1c990bdb3041b3007a7800d5d9fbe907.jpg681d4c8cd73839ae62c74e38aa19a335.jpg471c7f8a27e31373579d5161cf0e97d2.jpgdb17fa35d0237aff45daf4109404e040.jpg
These are some photos of the watch, as well as a front shot of it in case someone recognizes the model. I'm not sure how common this one is or isn't because I can't get to the model number on the movement.
Sent from my iPod touch using Tapatalk
Here's what I found on another Watchmaking forum regarding the superglue method.  Apparently you need a bigger tool.  That's what she said!  Amiright?
"How many people have tried to tell us now that this won't work? lol. We've discussed this before but I always use an aerosol accelerant to speed the setting of the glue. I have modified my holding technique a little though. I now hold the watch in a fielder's glove as I feel it affords a little better protection from shrapnel(either metal or crystal) and laceration. My 1/2" air impact is yet to be defeated on no more than 75 pounds of air pressure. [if any of you are actually gullible enough out there to try this at home, note: The space in the socket above the nut has to be packed with enough hard rubber to prevent the socket from contacting the case back and scarring it while allowing enough depth to engage the flats of the nut.] I suspect that the suddenous/severity/yadda/yadda the of the torque moment is such that it can conquer almost any circumstance it encounters. This is the primary reason I won't place the watch in a case holder in a vise. [That and it will either break the case holder or the lugs or otherwise distort the case.] If you have osteoporisis or are small boned or dimunitive in size - don't attempt this. Also - double check and make sure that the rotation on the wrench is flipped/pushed the right direction before you blast.
All for 25 cents pence worth of material. One last thought - just barely tap that trigger on your impact and then get off of it.laughing.gif "
Although it's not stated in this post, presumably you use the largest nut that fits on the flat portion of your caseback.
*Disclaimer*  I have personally never tried this technique as I am only a Junior Cadet Watchbreaker.  But I have welded nuts on broken bolts and studs whilst working on cars and it usually works brilliantly.  That and *cough, cough* a lot of heat and penetrating oil.
Oh, by the way, Howdy y'all!  Great site, great videos Mark!  Long time lurker, first time poster.  I'm hoping to work my way up to Senior Cadet Watchbreaker in the near future.
Cheers as you say,
American Dave
Welcome American Dave & agree that the superglue method works, just make sure that everything is thoroughly degreased & give the glue time to dry.
Welcome to the forum Dave! I liked your introductory post, it put a big smile on my face. I look forward to more input from you in the future. :)
By the look of the watch case more then one person has had fun getting the back off. Has someone had a go with hammer and chisel.
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
