Now that we've seen the watch it's almost certainly a screw back. What you really need is a high quality bench mounted opener to attack it with. It might be a good idea to source a watchmaker with one and get it opened safely if you are not wanting to try the glued nut method.
It had a LOT of light scratches on the back when I bought it, those I can get out once the back is off, I'm not too concerned about those.  But, I tried the superglued nut method TWICE, and both times the nut just popped right off. Yesterday on my lunch break I took the watch over to my repair guy that I've always gone to, and he couldn't get it off either.  He said, "It's like it's glued on." Thanks for the suggestion Geo, at this point I think I've pretty well run out of options, I'll do some calling around, I know there's several shops around by my work.
And, I believe the mystery of why it's not coming off has been solved.  It's still stuck, but I think we found out why.  I brought it to another shop today, and we believe whoever last opened the back cross threaded it... Which explains why it's not even budging.  Like you said Geo, time to source someone with a bench mounted opener.
By the look of the watch case more then one person has had fun getting the back off. Has someone had a go with hammer and chisel.
Hello all,
First post here. I recently acquired a mid 70s Seiko for parts (I spent more for the parts watch than a complete runner was worth, sentimental reasons and all). Anyways, I tried the rubber ball (I always start with that one) then the wench with no success. I then tried superglue with much doubt , it ended as I suspected I would. So I waited a few days and finally gave in to temptation. I put the watch in a case holder and into the vise it went , out came the hammer and chisel. One small tap in a slot for the wrench was all it took and didn't even leave a mark. First time I've had to use a hammer on a watch.
Also , once I had it open and looking on the inside of the case back there were no marks to indicate that it had even been opened.
Hello all,
You where lucky but if all else fails and it,s your watch then go for it.
I must say since I purchased the Horotec "universal case opener" no case no matter how tight has caused an issue. However it was £240 + you can buy separate dies for Rolex etc. but as a one off purchase it should last a life time.
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
