ETA 1080 Balance
I thought I was getting OK at hairspring manipulation until I tried to detangle one on an Omega cal 455 - ladies automatic movement (with sweep second) just 16mm diameter (very small and fiddly movements - best avoided). The hairspring was just 3.5mm diameter. Even with my sharpest tweezers working under the microscope I had to admit defeat and find a new balance. In the 'flat' I could correct errors, but trying to make vertical twists was beyond me.
By nevenbekriev · Posted
Yes, I understand. But one has to try, only this way the fear of the unknown disappears. I promise it will be not so hard to do and of course, if bending is too much, then lift it with some lever (bend it up) and with several iterations everything will be perfect. Never try to lift or bend down when the balance is in place, this is the important rule. If you have some useless movement, try and exercise on it. -
There are facebook groups ....but another forum that stores information from threads 🤷♂️ All we can do is wait and see what happens. -
Good luck. Interested to hear what lessons it teaches/reinforces.....
@LittleWatchShop I've seen one of those Trupoise tools on the ChronoGlide YouTube channel...Pretty amazing tool, but I went looking for one, and there were none on offer. It strikes me as similar to one of those JKA Feintaster bench micrometers: really neat, really expensive. 😁 @nevenbekriev Regarding shimming v. bending the balance cock, the permanence of the solution is something that I hadn't considered. It totally makes sense if one is going to be removing and replacing the balance cock more than once or twice. I'm just not sure (a) how I would go about bending and (b) how I wouldn't bend it too much. It seems like an approach best left to the professionals.
