ETA 1080 Balance
Wie ging die Sache weiter? please use English for your posts Tom
Heat from the wearer's wrist is causing internal moisture to settle on the glass. You could try putting it in a dehydrator for an hour with the back off -
By LittleWatchShop · Posted
It would be fine to try. Maybe start with a larger bezel and cut it down.
