Hi,
Thought you might be interested to see the attached photos of my £60 L-G Master Case Opener after its first use. Watch was clamped in the related Openall, no excessive force/torque was applied, one hand only used on the wrench, no great exertion. Either I'm a lot stronger than I realised (I didn't know I could snap steel one-handed) or it was actually a poorly made tool. I know the tool is highly regarded, and perhaps this is a one off bad one, but I am not impressed, not impressed at all. Looks like I'll have to be spending the big bucks on a proper tool.
Stephen
I'd send a copy of these photos to the company and see what they say. They are not cheap tools, and should be tested to forces greater than you could apply with one hand without breaking.
Looking at the slightly fuzzy picture of the break in the last photo, the grain structure looks a bit odd. It looks like it has been case hardened. Is there any evidence of a pre-fracture stress crack in the grain structure? This is usually evident by an area that is slightly darker in colour.
Hi,
First thing I did was get in touch with Cousins with the photos - they're waiting for the manufacturer to get back to them. It was very peculiar, I had hold of the handle and was pushing against it with one hand and had my other hand on the Openall (which is secured to the bench). I wasn't even pushing particularly hard, I was trying out how firmly closed the watch was, when it just went loose in my hand. There was no audible snap or break.
I'm no metallurgist and know nothing of tool construction sorry, I just assumed such well regarded tools would be better made. Looking at the break area on the handle under magnification there is a thin lighter coloured outer layer and a darker core. Can't see much evidence of a grain structure. One part has a clean break on the outer layer with a less clean but still quite smooth break on the core, the other side is slightly jagged. Hard to explain sorry!
Stephen
It could just be a rogue unit, Cousins should replace it if it is a recent purchase as it was not fit for purpose.
I've never known cousins to provide a refund or replacement, with their terms as a wholesale provider. But I'd be interested to see if they did.
Edited by Ishima
Unless they particularly exclude your statutory rights, which their terms appear to say they don't, they are pretty much the same as under SOGA anyway when it comes to faulty/not fit for purpose goods - as far as I know, I'm certainly no expert :). I'll just wait and see what happens.
Stephen
Thanks for the suggestion. I'm not sure right now that I feel like getting another hand operated one - this one was supposed to be one of the best ;)! As Geo said could well be a rogue, but it's enough to put me off. I'm going to try looking for a good second hand bench mounted version I think.
Stephen
Just thought I'd update this post. I had to send the wrench back to Cousins, who then sent it back to the manufacturer in the USA. They just received the report back from them which basically says too much pressure used by me and incorrect useage. Interestingly Cousins promptly refunded me and asked the manufacturer to explain how a steel tool intended for exerting pressure fractured under the force of a human hand.
All credit to Cousins for not taking the easy option to reject and choosing to back the customer instead. I'm still looking for a decent quality bench top opener though .
Maybe they had termites in the warehouse where the tool was stored! :pulling-hair-out:
OK! On a serious note, that tool looks defective (in material and maybe workmanship) so it should be replaced by the manufacturer. In any case, I'd like to know how the whole matter is resolved...You see, I own one of those and I admit I had to replace the bits...they were not strong enough. Maybe the quality is not there anymore?
Cheers,
Bob
Bob,
What I posted above was how it was resolved (at least as far as I'm concerned anyway) as Cousins refunded me in full. I don't know if they will be taking it further with the manufacturer but I won't be buying from them again. Initially I was willing to give them the benefit of the doubt and that it was just one of those things, but the fact that they took over a month to respond and then just tried to blame me without any explanation is too much for me. I'm just pleased that Cousins agreed with me that there was a problem with the item.
Stephen
    • Your only partially correct here. Let's look at a magnified view of the image up above. Then for a flat hairspring to function correctly there has to be a little bit of breathing room unfortunately. If you would like Better timekeeping if you get a watch with the over coil hairspring then those regulator pins are supposed to be as tight as possible but still allow the hairspring the slide. With if the pins are opened up at all you'll see a dramatic timing change based on amplitude. So in our example down below initially hairspring is basically free-floating not touching anything the effective length of the hairspring is at the stud. As the amplitude picks up at some point in time they hairspring will just tide should one pin on one swing and the other pin on the other swing. As soon as it does that it changes the effective length to being closer to the regulator pins. As the amplitude picks up more and more it's obviously touching the regulator pins more and more and the length of the hairspring shortens the watch speeds up. This is where in your video at around 16 minutes he opens up the regulator pins and the watch slows down. This is because they hairspring is no longer bouncing off either pin as much. Then because the watches running slow he speeds it up just to show that yes you could regulate the watch but now you have a problem. Because the regulator pins are much farther apart amplitude is going to have a much greater effect. Like in the image down below they hairspring is properly spaced between the pins. But if those pins are farther apart the effect of amplitude will be much greater. So he speeds up the watch to cancel out the effect of the regulator pins at the particular amplitude which was dial down then when he moves the watch to a crown position which will always have an amplitude decrease because the amount of friction on the sides of the pins now the hairspring is not touching the regulator pins as much and the watch dramatically slows down.   Let's look at the other example image. In this particular example they hairspring is actually touching the regulator pin at restWhich means the effective length of the hairspring is at the regulator pin the watch runs fast. As the amplitude picks up hairspring will lift off the PN moving the effective length towards the stud which is why the watches slowing down. As you can see is the amplitude picks up They hairspring is not centered C not getting even timekeeping and the watch is slowing even more down. But at some point in time when the amplitude gets high enough this will depend upon the watch the spacing Excedrin whatever the amplitude is will be balancing actually between the pins in the watch will of course speed up and then at some point time you reach that sweet spot where it's bouncing between the two pins but as you can see it's at a much higher amplitude. So this is why hairspring has to be properly centered between the pins and the pins have to be at the right spacing otherwise you going to get strange timekeeping based on amplitude which no matter what you're going to get a little bit of that as you do have to have a little bit a spacing. At least on a flat hairspring.
    • My understanding is that In the Etachron system the spring is only centered n order to set the stud angle when the the pins are wide open and the regulator block in at the midway point.  After that the pins are rotated in one direction only so that the width between the spring and one of the studs is 1/2 width of the spring. This results in the spring always being closer to one stud than other one.
    • The idea is that the spring is centred between the pins when at rest. Then when the watch is running it will oscillate equally between the pins i.e. bounce off one pin then the other, as the hairspring breathes. If the spring is only hitting one pin, then it isn't centred, and most likely the pins are too far apart. Yes, the regulator pins are there to adjust the effective length of the hairspring. The spacing of the regulator pins should not affect the amplitude.  The vertical positions typically have lower amplitude than the horizontal ones. This has nothing to with the regulator - hairspring interaction. Increased friction in the verticals sucks energy from the system and reduces the amplitude. If the amplitude is less, the breathing is less. More tim between the pins = more effective length. Depending on how well the hairspring is centred, and which direction it sags, some vertical positions might run faster than the horizontal ones, and others slower. For example, if the spring is off centre towards on pin, and pressed against it by gravity, it might never bounce off that pin => faster. At the position 180 deg. away, the spring will spend more time in between the pins => slower.
    • Thank you all for the tips and insights. I'm looking carefully at the Sherline lathes with a milling attachment. I need to figure out exactly what I'd need to get in terms of the base lathe and attachments to be able to fabricate basic parts and learn how to fabricate some of the less basic ones- like a cannon pinion. Thank you again.
    • Welkom Sebastiaan! Veel plezier met deze hobby!
