Picked up a pair of watches (both the same) and just had a look inside and had to do a double take..... what on earth are these??
They are Sovereign "ELECTRONIC", here is the front
Here is the inside:
I think the balance has a lug on it which is in close proximity to another lug... I'm thinking that the lug on the outside (see below) magnetically attracts the balance causing it to osculate and drive the mechanical element of the movement? Can anyone confirm this? Also, has anyone worked on this type of watch before, if so any hits/tips/gotcha's?
Here is the inside:
Electronic watch. Battery powered oscillator. Common ones are made by Timex and Benrus. If memory serves HectorLooi has worked on them.
Transitional tech. They're out there. That looks like a nice one. I think 10 jewels might be fully jeweled for that tech. You effectively remove the pallet and its associated jewels, and a wheel (7).
I've worked on a few electromechanical Timexes and have a Benrus in my "To do" pile. But I have never seen this movement before.
Still looking out for the grand daddy of all electric watches, the Hamilton Electric and maybe snag a Seiko or Citizen electric if it comes along the way.
I also have a very nice Kienzle electromechanical clock. I have also been toying with the idea of building a 1 second period, temperature compensated, long pendulum electromechanical clock.
The Benrus/Belforte/Sovereign versions of those watches usually use the LIP movement R148, so some of the service info that is available is written in French...But I think I have English manuals from Benrus that I could upload if they aren't readily available online.
Interesting? It actually seems to be a relatively common Electric movement as it was very inexpensive when it came out. Of course the problem with electric wristwatches is you never quite know what's inside Until you open the case up. Although quite a few of these came with transparent backs where you can see the movement
1 hour ago, Geotex said:
LIP movement R148
Yes that's definitely what it looks like.
Fortunately somebody already partially answer the question I would get a service manual if you've never done one of these before. Too many mysteries if you're not familiar with what you're looking at
While I'm sure somewhere around here I have a physical manual if you have a PDF yes it be nice if you uploaded it.
Why limit yourself to the Hamilton? For instance on this website look at the movement gallery look at all those electric watches you could try to acquire.
https://electric-watches.co.uk/movement-gallery/
Edited by JohnR725
    • Update!  I've dismantled it, cleaned all the glue off, and rebuilt and lubricated the base movement. I'll leave the chrono part for another day. It's running well - great amplitude and keeping time, but it's got a beat error of 4.8ms.    How important is it to correct this? I'm worried that the potential for making things worse having to take the hairspring off and on repeatedly to adjust this. Would anyone here accept it at that?
    • Since I've been banned from the previous discussion, apparently my language was inappropriate...for small boys. I will start another thread and act in a more decent manner for the girls and ladies of the group.  Please what will happen if the forum can't be managed by the administrator, are there provisions in place to preserve the achived member's questions and answers over the years. Please if I may ask these important questions that are important to the members please.
