Hi everyone,
Recently I bought Certin DS 2 ref. 5801 300 from if I'm correct ~1970 with 25-651 mechanizm.
I'm looking for some information about parts. I'm quite new in watches so may be that informations that I'm looking for are  obvious to you.
So.. I'm looking for original crown or at least certina part number.
In the internet I found crown for certina ds-2 that hase 6,5mm. But from my measurements it looks like it should have max 6mm.
And the next thing, crystal.
I found some informations that it was sapphire crystal but I'm not sure, maybe you know the part number of crystal or dimensions, or haw to find it.
I would be very grateful for any advice.
If you need any photos I can add them.
Yes, please add photos.
Finding parts for vintage watches can be challenging, but not impossible.
Once we see pictures, you will get more input.
New members should give an introduction here. Though not required, I like to have an idea of member's location (Switzerland, Nevada, S. Africa...). Members of this forum are very helpful.
Thanks for replay, I already introduced myself, but I didn't writhe my location. I'm from Poland.
I will add some pictures in the evening.
I found one picture on my phone.
Crown and crystal are not oryginal.
Edited by Piio
Thanks.  Sorry...I missed your intro--my bad!
I doubt that watch takes a sapphire or mineral crystal.
I think that crystal is too small becouse I can easily push it out by hands.
Crownt original and I think that it is to big and it stick too far out.
My dream is to have it waterfroof as mutch as I can. So good crystal and we'll fitted crown is wery important
"The Certina DS-2
Introduced in 1968, the Certina DS-2 carried on this tradition of robustness and maintained the DS system with improvements and a more durable stainless steel case design. These tonneau-shaped cases shared the turtleback feature and some further innovations. The crown is partially guarded by being set within the flow of the case flank, and it is secured with a twin seal."
https://www.fratellowatches.com/the-certina-ds-and-ds-2-vintage-value/#gref
That's the text from that site. My crown isn't sitting flat and it doesn't have seals so that's why I wish to change it.
I'm considering this one but I'm not sure will it fit and that is why I seek for some advice.
https://watchesulike.com/en/crowns-pushers/18742-certina-waterproof-crown-55-mm.html
Ok after loong sherch I found post on some forum that crystal is: 982/10 31.0-13 but it is really hard to faind, but it would be grate if someone could assure me that I'm not wrong.
DS, 31,0-6 and DS-2, 31,0-13 packages. It says DS on the DS-2 one but this is because it was used on the later DS watches as well."
https://www.watchuseek.com/threads/certina-ds-plexi-glass-crystal-for-ref-5801-112.5308515/
Thanks for that informations, I will look for that crystal.
One more think.. Normally under the acrylic crystal, and as far as I find out today it is acrylic, there are no gasket but this watch should be somehow water resistant. So.. Should there be any gasket?
For acrylic crystals, I have never seen a gasket. I don't expect I ever will. GS makes various waterproof crystals, e.g., magnitite.
No gasket, but tension ring. This original crystal for DS/DS2 is much thicker.
Thanks all for replays, I will look for original glass and crown.
When I'm done I will post some pictures.
Ofc If anyone has the dimensions of the crown, I'd be very grateful
  • 4 months later...
Did you ever find a genuine crystal for your DS-2 ?  I cannot find one anywhere. Is there a generic alternative ? And what is its reference and where to get it ? Much appreciated.
  • 5 months later...
Sorry for the delay, currently I don't have space to work on the watch so I stopped the work. But I found crystal for the watch. I will try to remember to do the photo when I will be back at home.
  • 3 months later...
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • Agreed, this is puzzling. Can you ask questions or inspect the lots before bidding? My Boley & Leinen Reform face plate is dia. 95mm exactly. It's possible that 4 inches is a slightly too large approximation, but why then make the distinction to 3 11/16 for the sake of 8mm? If the larger ones are truly 4" then they will clash with the bed, but then I have no idea which 8mm lathe would take them. All 8mm lathes have spindle height 50mm or less, as far as I know. The spindle height is, as you say, standard 50mm for W.W.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
