This is now part of my collection. Bought the watch at a car boot sale.  It was in good condition but didn't work. Broken mainspring.This watches where given to every employee at the Volvo factory in 1977. That was when Volvo celebrated there 50 anniversary. 1927-1977 . There are some different watches. All blue but different shades.  But can't say what the difference is? All are Certina blue ribbon. Inside is a Eta 2783 movement. And have put it on a original Tropic strap.
post-644-0-84491000-1439234499_thumb.jpgpost-644-0-65386300-1439234487_thumb.jpgpost-644-0-38753200-1439234494_thumb.jpg
That's an interesting collectors item you've picked up Roger piece you've picked up Roger, and a really tidy job of restoration. :)
  • 9 months later...
Rogart, I don't know whether it's still of interest to you, but here is some additional information regarding your "50 years of Volvo" Certina: Volvo issued some 64,000 watches to employees not just in the factory but all around the world in order to celebrate "50 År Volvo - 1927 - 1977". Certina was at the time a prime supplier of watches to Volvo who issued them as 100,000-km-presents to valued customers. So it was quite natural that Volvo turned to Certina when it came to a gift for the celebration of Volvo's semi-centennial.
Basically, there were two types of watches: for male employees, Volvo issued the Certina Blue Ribbon with a steel case, for women the Certina 'Mayfair' with a gilt one. The watches were taken from Certina's 1977 range. I don't know much about the 'Mayfair', but the 'Blue Ribbon' was actually equipped with an in-house movement, the well-developed 25-651/25-651M. I'm pretty sure that actually all Volvo watches were meant to be delivered with the in-house caliber. However, Certina's capacity at that time was at around 650,000 watches per year, and the production of mechanical movements was in the process of being wound down, so it's easy to see why an order the size of Volvo's, mopping up some ten percent of Certina's overall capacity, could not be fulfilled with in-house movements alone.
Therefore Certina bought additional ETA movements (ETA 2783) which were refined and renamed "25-011". Because the arrangement of the date ring was slightly different, new dials needed to be used as well, with a slightly smaller date window aperture set slightly to the center when compared with the original dial.
These dials were in a greenish hue (like in your watch) whereas the original ones were blue. Held next to each other, the differences between the two watches are easily discernible:
Enjoy your watch! I hope you brought it back to life!
Best regards
Andreas
PS: Do you drive a Volvo, too? ;-)
Best regards
Andreas
Hi Andreas
Very intresting to learn about how the watches was developed. And why there are two different versions. My Certina Volvo has left the building. It was sold to a friend that is a very keen Volvo fan.
I see this watches a lot on Swedish auctions.
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
