I recently purchased a brand-spanking new Sherline lathe, which has the ability to cut threads.  However, I am still unsure of how the stem tap measurements work.  Some websites say that the tap is proportional to the thread diameter (larger diameter = larger tap).  Some websites say that the tap is inversely proportional to the thread diameter (larger diameter = smaller tap).
Then there is the issue of what the actual thread pitch of the stem is.  Assuming the simple approach of tap being proportional to diameter, what is the thread pitch or TPI of these tap numbers?  I've read that it closely resembles the Bourgeaux thread series.  But I can't get a straightforward answer of what exactly the Bourgeaux thread series is.  Different websites report different numbers.  I can't find an authoritative source to get the actual numbers.
That defo warrants a photo Greg, what on earth were you thinking ? That you could get away without one 🤨
Because I purchased it so recently that it hasn't even shipped from Sherline yet. 🙂
Hi John, that was one of the websites I found before making this post.  I bought the inch version of the lathe, but you can still cut metrics threads.  The instruction manual for the thread cutting attachment includes the gear setup for cutting metric threads on an inch lathe and vice versa.
9 minutes ago, oldhippy said:
Here is the table for  Bourgeaux thread series.
https://www.sizes.com/tools/thread_bourgeaux.htm
Thanks hippy.  That was one of the websites I was referring to when I mentioned that different websites report different numbers.
Mainly
and
https://www.chiark.greenend.org.uk/~alanb/martin.html
The sizes.com also has a page on the Latard series, and gives a reference to a nearly 100 year old German book.  So at least it's something to go by.  But there are no such references for the Bourgeaux thread.
Then there's also this book (p69 and p70) which reports that Bourgeaux had a pitch of 0.94^n or 0.9^n, neither of which conform to those two websites.
https://www.researchgate.net/profile/Randall-Brooks/publication/233455494_Standard_Screw_Threads_For_Scientific_Instruments_Part_I_Production_Techniques_And_The_Filiere_Suisse/links/568c0ec708ae153299b63b04/Standard-Screw-Threads-For-Scientific-Instruments-Part-I-Production-Techniques-And-The-Filiere-Suisse.pdf
However, this whole point is moot if there is a place that can give the exact dimensions of current stem threads.
The problem with looking for certain specifications is the specifications only exist if someone is trying to make that item typically. The problem becomes finding the specifications become problematic if nobody's actually making stems and him.
Then at one time they used to make a set for re-tapping the crown. The that a holder for the crown a drill and a tap and it was made by star and that's all the information you get the sizes are intent's of a millimeter. But it doesn't say give the guy information you're looking for as I didn't assume you be using it to try to make a stem.
There is a couple links you might have missed perhaps
https://mb.nawcc.org/threads/watch-stem-threads-made-on-sherline.157058/
I think this one covers the same stuff you have but to put it here anyway
https://mb.nawcc.org/threads/watch-stem-tap-sizes.124651/
I think probably what you're going to have to do is get stems of the size you like to make and imitate the threads that you find on them.
For modern (last 100 years) non-U.S. stuff it's metric. You can find the thread pitches here for each diameter. Don't worry about how metric (sort of) corresponds to Martin threads, especially if you will be cutting them on a lathe.
As promised.
I went with the CNC-ready package, so I had to supply my own motors. I've written a rudimentary "CNC" program in Python that takes an SVG outline of a balance staff that I create and moves the motors to cut accordingly.  But I haven't stitched all the pieces together yet.
They are also closed loop stepper motors, meaning they have an internal feedback mechanism to accurately control the position.
Edited by GregG
5 hours ago, oldhippy said:
Are you sure its big enough to make a watch stem. 🤣
On a somewhat related note, I found a video about the American Precision Museum, and they had one of the machines used to make watch screws (at 48 seconds if it doesn't automatically jump to that point).
I believe this is an identical machine in action, amazing for 1870s!
I think the video you linked to is the video that is playing on the iPad in the museum video. XD
Edited by GregG
    • Update!  I've dismantled it, cleaned all the glue off, and rebuilt and lubricated the base movement. I'll leave the chrono part for another day. It's running well - great amplitude and keeping time, but it's got a beat error of 4.8ms.    How important is it to correct this? I'm worried that the potential for making things worse having to take the hairspring off and on repeatedly to adjust this. Would anyone here accept it at that?
    • Since I've been banned from the previous discussion, apparently my language was inappropriate...for small boys. I will start another thread and act in a more decent manner for the girls and ladies of the group.  Please what will happen if the forum can't be managed by the administrator, are there provisions in place to preserve the achived member's questions and answers over the years. Please if I may ask these important questions that are important to the members please.
