FHF identification help
It looks pretty old. Also I'm struggling to find anything by FHF that size, and with matching keyless works. It is a bit of an odd ball.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&FHF_Robert_8
Quote
Remarks
FHF ran several factories in Fontainemelon, and one was named after the founders Fabrique Robert. The calibres produced there are recorded in few registers (pretty poor and contradictionary) under names like Font Robert, FF Robert, FHF Robert. Bestfit mentions the Gruen 103 as an FHF Robert 8.75''' downsized to 8'''. But the example here (from a Wilka Watch) demonstrates, that this size was available right from factory. Obviously the 8.75''' calibres Gruen 100, 101, 620...623, 626, 627 are also based on this calibre, and are accordingly listed here, but realiable informations can't be given here.
Swiss Patent 51482:
filed 05-03-1910, FHF, Fabrique d'Horlogerie de Fontainemelon (CH)
setting mechanism without setting-lever spring
Example, year: signature; shock device
ca. 1925: - 9686, +51482
That is also similar, but the keyless doesn't look right.
Edited by AndyHull
35 minutes ago, lxt123 said:
I think that the serial number is 32746 on the barrel bridge.
118 calibre?
18 minutes ago, mikepilk said:
I've just finished trying to identify some scrap movements I bought. I think this is an FHF 1146.
The keyless looks the same. Though it measures 23.3 mm
In the flume catalogue i have the 1146 came in sizes 8 3/4'"   9 3/4'"   and 12'"
1180 ? The 80 accidently  double stamped
38 minutes ago, lxt123 said:
I'm trying to find a balance staff for it.
It looks identical with the FHF 1156 from Andy Hull, only that this is 15J. and 9-3/4 ligne.
I wonder if the staff will fit.
Do you have the staff to measure up ? Balance staff . Com list an fhf caliber 119 at 9  3/4'"
  • 7 months later...
3 hours ago, Giogrlj said:
I need a balance spring and a pallet fork for this movement. Any idea where to find it?
On the dial side of the watch is stamped FHF8, but obviously this is a variant of FHF 1156 (different bridges).
Your only real chance is to find a donor movement on eBay.
Different bridges don't mean fork and balance springs are different too.
 Fork and balance are parts of the escapement, designed to beat at certain rate which the entire escapement is suppose to produce, so you should base your search on beat/ frequency of the caliber you have .
As clockboy suggest your best chance is to find a donor, or a balance complete.
Balance spring off of two new balance completes of same caliber & frequency  won't readily interchange, though can be made to produce the design beat.
Prior to mass production of balance complete, watchmakers had to vibrate balance & spring to build a balance complete.
There many discussions on the subject on WRT forum.
Rgds
Edited by Nucejoe
Rgds
Thank's
