3rd times the charm, right?
Hey guys, I have been on the quest for some reasonably priced mainspring winders for a month or 2 now. So far, I have learned I can't afford a Bergeon set and my last Ebay auction I was considering went up to $250, too high for my liking right now. But, there is still hope! These mainspring winders below are on Ebay for $150, within my budget, and look to be in good condition. My only 2 questions I care about are, how do they work and are they complete? I want to be 100% sure about these before buying.
Also, I found a catalogue with the "Federwinder" model with the same metal base
And finally, an old listing I found with a picture of the arbors/handles out
My only guess is that the arbors wind the mainspring into the according circle in the base, then there is a spring-loaded pusher that pushes the mainspring out?
Thank you for any help!
I don't think there is any mainspring winder set that will be able to fit all the watches you'll will work on in your lifetime. Either the barrel size is wrong, the arbor size is wrong or the winding direction is wrong.
I have already accumulated 5 different sets, from very small ones for ladies watches, to very big ones for pocket watches. But every once in awhile, there will be some odd sized mainspring that just won't fit any of them.
So my advice is if you are serious about watch repair, just jump right in and throw your paycheck into the black hole that is horology. 🤣
  • Haha 2
Lol, so true Hector. I earn good money but my bank account seems have steadily dropped since i started.
I am in the same boat..... just when i think "that's it... I dont need anything else for a good while" someone on here posts about a new tool or gizmo that they have that then become my new must have fix...
With you mate. So when you getting my posted hairspring vibrator then 🤣
With Hector on this one, i have 3 sets and 6 adjustable ones. You just can't have too many. But what you have here is a starting point, if the price is ok then go for it. You will add to it anyway no matter what you buy. Thats just the nature of the beast. Its about being patient and buying wisely.
4 minutes ago, Waggy said:
ha ha is that the one with the self sealing stem bolts or the one with the Jhonson Rods
Not even going there, that sounds way too kinky for me lol. Just thought I'd mention the expensive one i posted on Saturday, I'm sure you'll need it soon. Yeah we all know it don't we Rich is a real ass 🤣
    • No not baby photos, teens to early 30s. With the bike about 20, graduation about 30.
    • This is wrong. We have been talking about the regulator pins because conventionally the regulator is two pins, or a pin and a boot. The Etachron regulator is one round pin with a wide slot down the middle for the hairspring to sit in. To regulate, the pin is rotated anticlockwise (viewed from above) which brings the rear inner and front outer corners of the slot equally closer to the spring. You can download a document with detailed instructions here: https://calibercorner.com/etachron/
    • Than you so much for taking the time to write such a detailed and informative post. It really helps. So, another question: With the Etachron system the stud pushes into the carrier but the angle on the vertical plane of the stud is based on the carrier arm. I expected it to be flat but I have seen some movements where it is bent slight down meaning the stud is pointing slightly inward at the bottom and the spring leaving the stud is affected. Is this something that is done at the factory to flatten the spring?  I played around with manipulating the spring vertical angle as it leaves the stud and it has a significant effect on how it goes through the pins and also the angle of the coils on the other side of the balance. I can flatten the spring by adjusting the angle it leaves the stud. Now I know the NH35 is a mass produced movement so not the best quality but is the stud vertical angle ever manipulated to flatten the spring?
    • Because the water is very hard with calcium where I live, and I saw that on a youtube demo 🤔... Maybe it's unnecessary...
    • Why deionised water for a pressure test?
