Introduction
I use a Jack industrial sewing machine motor on my Pultra I can’t fault it although I have converted from foot to a potentiometer the torque even when running slow is excellent. check out my videos on YouTube to see it in use @torsiondell. Dell
I have a slot in a block. I didn't think Etachron had slots with a keeper like some Swiss systems.
Do you have regulating pins, or a slot as per a normal Etachron? Post some photos.
By LittleWatchShop · Posted
I will post some pictures later -
Yes, I understand that in te Etachron system the regulator block is turned anti-clockwise. If I look at the spring in relation to the pins as I turn the block the gap appear to be "closing" and the spring is now closer to one pin than the other. Closing is not the correct term because the pin gap is always contant but in relation to the spring the gap appears to get smaller and smaller until the spring is actually on the pin.
