Just finished servicing a Seiko 5740. The first watch I've done which was working (after a fashion) before I touched it. It had a 2.3ms beat error which needed to be addressed, but was nervous because 4 movements ago, my screwdriver tip slipped off the stud carrier (quite stiff to move) mangling the hairspring. After a bit of thought (and a nappy change), I used a triangular diamond file to cut a V shaped notch in the end of a 2.5mm screwdriver blade (a lot more difficult than it sounds) and I have to say, the tip (provided its placed accurately using a loupe) feels much more stable and less likely to slip. Are there any other techniques or tips I need to be aware of? Its not quite Ian Drury, but its close enough!!
There are T profile screwdrivers, which i am waiting on to try, but the feedback i have seen is positive, see the difference below:
They are made with a very fancy and crazy expensive sharpener:
The potential good news is that I am designing a 3D printed version of the sharpener, so if you have access to a printer and can wait a week or two (need a new cooling fan for my printer) I can share the files needed to print one.
Hit it Doc 👍your new tool sounds like a good addition. Personally i use pegwood to do this. I tend to prefer wood on metal ( steady boys and girls 😄 ) for these sort of applications. My choice here being that steel on steel has little friction and the impact of steel damage is much higher than timber.  One reason ive started to look at various timbers for jewelling and staking accessories. Another example is the shaped tooth pick kif spring removal tool compared to purpose manufactured ones. I have a few of those and they can be a bit aggressive on the spring and dont especially grip that well ( low friction contact ). Just throwing  other ideas at you matey .
We had a good discussion about these 18 months back. The general consensus was # a bit gimmicky and not really practical #
I was taken in by the idea but various opinions quickly had me rethink. First thought once shaped to what is known as hollow ground, the blade will only fit accurately one size slot of screw offering lower stability to a wider slotted screw ( slips easily ) The wedge shape blade can grip the slot of more than one size, with much better side friction the main advantage of a wedge shape. Hollow ground blades mean more drivers to accommodate varying screw sizes and slot widths. Coupled with extra maintenance time puts them more into a specialised bracket. The wedge profile is quick and easy to maintain.
i use pegwood to do this............
That sounds safer than my brute force tool and I'm pretty sure the peg wood would be easier to shape. This is the reason for coming to the forum, field tested solutions which just make sense.
6 hours ago, Waggy said:
There are T profile screwdrivers.........
Now I think about it, I could have made life a bit easier by using my diamond file to flatten and then undercut one of the screwdriver bevels (across the width of the blade ) as opposed to cutting a notch in the end of the blade, so thats half a "T"
True to form, my 2D handwriting is illegible so goodness knows what my 3D printing would look like! My hollow grind woodworking chisels allow me to get a scarily sharp edge quickly.
👍Hollow grinding works very well with chisels and is the natural shape achieved from using a grinding wheel in a vertical position. With a chisel this makes sharpening  the edge and subsequent sharpening fast & easy and as Doc says gives the tool an insane edge. Something you obviously don't need to have with a driver's blade. I curiously wouldn't mind having my memory refreshed on the positive aspects of the T profile blade though.
You will find at some point you will need to adapt tools when it comes to some repairs, it happens to us all. Part of the fun in having a lathe is being able to make tools for your work.
I may have mispurchased ........ my lathe weighs 800Kg is 1.8m between centres, 0.5m over the bed, runs off 400V 3 phase, so I'm guessing a tad too big! However it does give major bragging rights and more than makes up for my diminutive genitalia.
Yes but think about the newels you could turn out for that amazing four poster bed you've been promising the missus, that will take her mind off the other 😄
Funny you should say that. One of my post retirement goals was to replace all the crap furniture in our house with stuff I'd designed and made myself. Mostly from air dried English oak (before I went to med school, I worked in a timber mill where I caught the wood bug). Although its not a four poster, the bed's already done!!
I just use a spring bar tool as it already has a V shaped notch on one end. Every time I order a watch strap, bracelet or spring bars from AliExpress, the seller would include a free spring bar tool. I have a box of them already.
I did give that a try, but for my miniature hands, it was just a tad too large to wield accurately 👍
