Hope someone out there can help me before I go caveman on my balance spring. I just finished disassembling and cleaning  a watch and all was going well, too well, the balance has am amplitude of 270° then I put on the dial and hands on and turn it over ready to case up when i notice the balance is barely moving. I retrace my steps and remove the hands and dial, but still sluggish balance. I remove the balance and re-seat it and all is well again... Then for no reason it goes sluggish again.
Looking under the scope, sorry no pictures, not a fancy trinocular scope, I can see some of the coils are sticking together. So I demagnatize and all is well again....got it sorted...how smart am I! Then after 10 mins or so it sluggs again...back to the demagnatizer, it wakes up only later to get sleepy again...
So now I'm thinking oily hair spring, so I remove the balance and submerge in hexane, good soak +/- 30 mins. Then confirm there are no kinks or bends in the hair spring, and replace, re oil the balance jewels..... Got it this time.... But no.... Slug city. Repeat the soak, this time in naphtha first, then hexane....same story.
I look again at the coils all straight and no kinks or bends or obvious clumps of oil or fibres etc, I'm at a loss.
I was about to drip acetone on the coils, but talked myself into calling it a night and watch some TV.
Any ideas where to go next, before I end up doing something stupid and junk the watch?
Pick the bones out of this time trace
If it wakes up after being demagnetised and then slows down again, is it somehow being remangetisted?
I was assuming the demagnatizing process was shocking the spring loose, then after a while it was re-clogging?
I've had this problem - ran the balance through the U/S cleaner 2x with Elma cleaner/rinse/IPA, and still sticking together. I did try acetone, and it solved it for me. From what I've read, it doesn't dissolve shellac
definitely an interesting picture doesn't exactly look like a magnetized hairspring.
we don't know the background histories of watches like how they were treated. So as we don't know what exactly is on the hairspring as far as we will loosely call lubrication. So it's always conceivable that whatever it is whatever rinse your using doesn't rinse it off.  then I would try something different then you probably don't have to leave it all day in the rinse whatever it is is probably relatively thin hopefully is try some other chemicals even for dissolving shellac unless it's at elevated temperature it usually doesn't dissolve instantly it takes a little bit of time which means your incident just about anything you feel like at least for a short time span
The calibre was never mentioned but if it is somewhat modern we can likely assume the impulse pin is friction fitted rather than fixed with shellac so I don't think there's anything to worry about. Nevertheless, in my experience, acetone is one of the more efficient chemicals to dissolve shellac.
I did a quick Google, and the opinion seemed to be it didn't dissolve shellac - I should have looked deeper.
Anyway, similar to IPA, a few seconds dip should not be a problem on the shellac, but may solve the spring problem
Modern impulse jewels seem to be friction fitted or glued in. So they are probably more resistant to IPA and acetone. But vintage watches that are shellaced, it's probably not a good idea to use acetone.
Elsewhere in this forum, another member wrote about Chinese hairsprings unglueing from the stud after cleaning. So, it's not an urban legend or myth.
Here are some pictures of the movement in question:
So this watch is circa 1962, and there is the number 810 on the movement which I assume is the calibre.
I left the balance soaking in fresh hexane over night, I'll try it out when I get home from work and feedback.
😱 Good point! I never even thought about that! 👍
I thought you would be able to physically see the coils sticking together.  I'm sure everyone has experienced this effect from both magnetism and adhesion. I would want to know which it is before taking further action. My first thought, what could possibly be on the hairspring that is so different that it can't be removed with the usual cleaning fluids that most people use. Maybe its not an adhesive like we imagine, so attention drawn to magnetism.  Mild re magnetism as it enters the movement's space something in the movement that is magnetised or the tweezers that you are using ?( even supposedly anti magnetic tweezers can hold a tiny amount ).   I had a similar quandary about six months back, so i set up the highest magnification i had at the time which was x40. Then slowly watched the coils contract as i rotated the balance wheel . I could see the coils suddenly pull together as they started to got closer. Demaging the whole watch solved the problem,  it was just something i had forgotten to do before i started work on the movement.
That's a good idea, I'll break out the high magnification eye pieces on my microscope and see if I can spot the coils jumping together or otherwise interacting magnetically. I'll also take the added precaution of demag-ing any tools I plan to use prior to working in the watch.
Think I got it!!!
Looking through the microscope it didn't see any signs of magnetism, but just to cover all my bases (shotgun approach!) I de-magged the watch and prior to working on it I demaged my tools also. I then soaked the balance in hexane for 24 hours and then naphtha for 10 mins, then IPA for 5 mins, then acetone for 5 mins allowed it to dry out for an hour and then oiled the jewel. I took a good look at the hairspring under the highest magnification and noticed no coil sticking, but I did notice the tiniest of kinks in the spring, usually I would have ignored it as it was so minor, but I corrected it this time.
Anyway, something or a combination of things above seems to have done the trick - its not an expensive watch or particularly beautiful, but I wasn't going to let it beat me!
Thanks everyone for your help and suggestions - it's nice just to have a sounding board and bounce ideas off people rather than working in isolation and heading down a 'rabbit hole'!
Edited by Waggy
7 hours ago, Waggy said:
Just to close the loop, here is the finished watch:
I absolutely disagree! It is "particularly beautiful"! Congrats, and as a watch repairer, defeat is never an option! 😉
Edited by VWatchie
    • No not baby photos, teens to early 30s. With the bike about 20, graduation about 30.
    • This is wrong. We have been talking about the regulator pins because conventionally the regulator is two pins, or a pin and a boot. The Etachron regulator is one round pin with a wide slot down the middle for the hairspring to sit in. To regulate, the pin is rotated anticlockwise (viewed from above) which brings the rear inner and front outer corners of the slot equally closer to the spring. You can download a document with detailed instructions here: https://calibercorner.com/etachron/
    • Than you so much for taking the time to write such a detailed and informative post. It really helps. So, another question: With the Etachron system the stud pushes into the carrier but the angle on the vertical plane of the stud is based on the carrier arm. I expected it to be flat but I have seen some movements where it is bent slight down meaning the stud is pointing slightly inward at the bottom and the spring leaving the stud is affected. Is this something that is done at the factory to flatten the spring?  I played around with manipulating the spring vertical angle as it leaves the stud and it has a significant effect on how it goes through the pins and also the angle of the coils on the other side of the balance. I can flatten the spring by adjusting the angle it leaves the stud. Now I know the NH35 is a mass produced movement so not the best quality but is the stud vertical angle ever manipulated to flatten the spring?
    • Because the water is very hard with calcium where I live, and I saw that on a youtube demo 🤔... Maybe it's unnecessary...
    • Why deionised water for a pressure test?
