Eyup watch peeps. I have just received another useful book addition . There are sites containing this information, one in particular is the balance staff and stem .com site. A very handy database when searching for information on sizes. But it is an actual retail site so may not be around forever. If you google ronda catalogs there are also pdfs that you can download, i will add a link, but the stem pdf are not complete to the book. Everything is there but only is alphabetical order of make. Not grest if you have a stash of stems by ronda number order which  i happen to have. This book will save  days if not weeks of searching and identifying ronda numbered stems also unknown stems.
https://vintagewatchparts.net/ronda-winding-stem-catalogue/
Edited by Neverenoughwatches
  • Thanks 2
  • 1 year later...
I took the catalogues that you can view page-by-page at vintagewatchparts.net and made handy pdf's:
Ronda Winding Stem Catalogue:
Ronda-Stem-Catalogue VintWatchPrts.pdf
Ronda Balance Staff Catalogue:
Ronda-Staff-Catalogue VintWatchPrts.pdf
DCN Winding Stem Catalogue:
DCN-Stem-Catalogue VintWatchPrts.pdf
DCN Balance Staff Catalogue:
DCN-Staff-Catalogue VintWatchPrts.pdf
In the case of the Ronda stems, there is a mistake on the website whereby two of the pages are substituted by the correspondingly numbered pages from the staffs catalogue. I informed the website, and the error is corrected in my pdf.
I hope they're still exciting reading even though I've removed the twist in the plot.
Edited by PQR
Added keywords for search
There's actually quite a bit of info missing on the vintage watch parts downloads as well some other sites. The more detailed book have 3 sections, by alphabetical order, by size and by code numbers. This allows users to cross reference through the sections which is great if you have an unknown stem or staff.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
