I have an ETA 959.001 movement (Concord Quartz Watch). I am getting regular pulses and the gear train seems to be free (Horotec Turbo used to test)
When the watch is running on its on I only get occasional minute hand movement.
Of course this movement is no longer being produced. Are there any suggestions for a replacement movement  or should I begin to dig deeper looking for possible gear damage?
Any help would be appreciated.
Edited by robertswatches
added info
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
