Hi there first post!
I have a Montblanc Profile XL, with a dead battery. I'm perfectly confident that I can change the battery myself, as I have in many other watches - but am not sure how to open the case on this one. It is a rectangular watch, with, not surprisingly, a rectangular back!
Is it a simple matter of prising it open (will I need to remove the bracelet to do this?), changing the battery, regreasing the seal and pressing the back into place again - or is there more to it than that?
Many thanks in advance for any advice,
Patrick.
Welcome to the forum Transam.
What you describe above sounds correct. You may have to remove the bracelet to find the little notch for the case knife as it is sometimes hidden there. Once you have removed the bracelet, clean around the edges thoroughly with a stiff brush, then using a loupe check around the case to find the notch. When you find it, use a good quality case knife to prise the back off, but do it I such a way as not to slip into the movement and cause damage.
Ah, so there should actually be a notch present to put the case knife into? That's a bonus! I shall try taking off the bracelet this weekend, and have a look - I can't see any notch with it in place, and just "levering" around would be using the bracelet retaining screw as a fulcrum, which I am sure would damage it.
Many thanks Geo - I shall report back!
Patrick.
Of course, before doing all this you must ensure you have the correct tool and accessories to refit the caseback.
Case/crystal press with the correct size/shaped dyes.
I'm actually quite adept at casting (aluminium/lead mostly, so happy to make my own custom shaped die to keep pressure off the crystal - and I have a small screw press which was owned by my late great-uncle (who was a watchmaker), so that part should be fine as long as I can get the thing open! It'd be a lot easier to take it to a watch repairer, but where is the fun in that? :thumbsd:
I shall be back... thanks all for your help to a newbie!
Many thanks, gents. there was indeed a good wide notch available (without removing the bracelet) and it took a little pressure to pop the back off.
It takes a Renata 394 battery, I have ordered a couple!
As before, I shall keep you updated when it all explodes in my face...
Many thanks to all,
Patrick.
That's good Patrick.
If you don't have a press for closing the back and are doing it by hand, make sure you squeeze at the edge of the case as it is easy to break the crystal by pressing in the middle.
Thanks gents, you are all stars! The batteries arrived yesterday (but I was drunk) - so left it until today. The new battery basically fell into place, and the case closed (after lightly lubing the gasket with silicone grease) with as little pressure as it took to open - basically finger pressure around the case and back, and it just "popped" back in and feels very solid (no gaps!).
It now works perfectly once again, all for the grand cost of £1.25. I wonder how much Montblanc would charge...
Many thanks to you all for your help, and I will be back - I have a few other watches that need fiddled with - a genuine Rolex Air King, and two Rolex "Homages" (horribly cheap but remarkably accurate fakes) - a Sub and a Daytona.
Thanks again,
Patrick.
    • Yes, I understand that in te Etachron system the regulator block is turned anti-clockwise. If I look at the spring in relation to the pins as I turn the block the gap appear to be "closing" and the spring is now closer to one pin than the other.  Closing is not the correct term because the pin gap is always contant but in relation to the spring the gap appears to get smaller and smaller until  the spring is actually on the pin.
    • I have one of these (different colour scheme) very happy with it! Not so happy with the recent results...  but that is nothing to do with the tester. My wife wanted a waterproof watch she could take on holiday so I fixed up a nice Mickey Mouse Seiko 5 for her.  But after getting a non runner working nicely it failed the pressure test with water seeping in around the crystal 😞
    • No not baby photos, teens to early 30s. With the bike about 20, graduation about 30.
    • This is wrong. We have been talking about the regulator pins because conventionally the regulator is two pins, or a pin and a boot. The Etachron regulator is one round pin with a wide slot down the middle for the hairspring to sit in. To regulate, the pin is rotated anticlockwise (viewed from above) which brings the rear inner and front outer corners of the slot equally closer to the spring. You can download a document with detailed instructions here: https://calibercorner.com/etachron/ Can you please post some photos to show what you mean by "flatten the spring"?
    • Than you so much for taking the time to write such a detailed and informative post. It really helps. So, another question: With the Etachron system the stud pushes into the carrier but the angle on the vertical plane of the stud is based on the carrier arm. I expected it to be flat but I have seen some movements where it is bent slight down meaning the stud is pointing slightly inward at the bottom and the spring leaving the stud is affected. Is this something that is done at the factory to flatten the spring?  I played around with manipulating the spring vertical angle as it leaves the stud and it has a significant effect on how it goes through the pins and also the angle of the coils on the other side of the balance. I can flatten the spring by adjusting the angle it leaves the stud. Now I know the NH35 is a mass produced movement so not the best quality but is the stud vertical angle ever manipulated to flatten the spring?
