First microscope
Hello everyone, my boss wants a microscope in our service. Would be great if you recommend something good around 9k dollars or less with light under the platform where the object is laying and may be with an option of output to the screen.
Thanks
You have a nice budget, which  is helpful.  It means that you can go with one of the better manufacturers like Nikon, and won't be limited to medium or low quality Chinese kit.
Rather than a specific scope, I'll recommend  a class of scopes and some ideas so that you meet your requirements.
First, the microscope head itself. This would be a Trinocular stereo scope, stereo eyepieces and a separate port for mounting a camera. It should be simul-focus, which means that focus for the eyepieces and the camera change together. You can choose camera type and resolution, and then connect the output to a screen size of your choosing, and most have the ability to record to built in card, or can be connected to a computer.
Then, you need to decide on what kind of stand/mount you want. I would highly recommend a boom stand, a dual boom stand can be very sturdy and stable, and allows great flexibility in positioning the head and moving it out of the way when needed. This is the setup most often used in "inspection" microscopes, ones that are used in manufacturing, and are common in the electronics manufacturing and repair industries.  This is a much larger market than watchmaking, but since the requirements are much the same, we get the benefit of all that development.
Don't be tempted to buy the stand that is sold for use in a scope meant for biological use, that has the built in light for backlighting a specimen slide. Unless you are very space constrained, this will limit the flexibility of the scope. In other words, you won't be able to set it up over your lathe. A better solution is to either build or buy a "light table", and set your parts on that when you want them illuminated from underneath.
As far as magnification, common basic zoom head will be approx. 1x - 5x, Using 10X eyepieces makes it 10X - 50X,  if that's too much you can add what's called a "barlow" lens, which are available in different strengths. I use a 0.5 for most of my work, which on my scope gives me a magnification range of 3.5X to 22.5X, which to me is the sweet spot for disassembly/assembly.
Lighting is also very important. I use a ring light, which is attached to the nose of the scope, but there are also more powerful lights that are on "goosenecks" that allow you to position the lights to best effect. It seems to me that more light is almost always better, but then again I have old eyes 🙂
Good luck with your search!
They are mostly used by artists, my wife has ours and I can't find it, or I'd take a picture.  Ours is old, modern ones are better but I can't recommend specific one.
Here's a link to one on US Amazon, should give you an idea of what I'm talking about.
https://www.amazon.com/Lightmaster-Diagonal-Lightbox-Super-Bright-Ultra-Thin/dp/B00NRE2G6M/ref=sr_1_33?keywords=light+table&qid=1692564673&sr=8-33&ufe=app_do%3Aamzn1.fos.f5122f16-c3e8-4386-bf32-63e904010ad0
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
