Hi guys, just wanted to share my latest completed project. TBH I'm extremely proud of the results, as its the first watch I've done without any instructional videos or manuals etc.
I purchased the Watch for £50 off ebay as a non runner, partially due to the price & I've developed a liking of 36000 vph movements. When it arrived I immediately noticed the glass was cracked, dial had dirt spots & crown was stuck in the setting position. The case wasn't in particular good shape either. c3939888700c236a7554df8e97ec7d79.jpgafter doing abit of research on dial cleaning, ordering a new glass & a new mainspring I felt ready to take the plunge.
Firstly I removed the movement & cracked glass. 756cfa2d2cae27d9367cd0952e8aa638.jpgOnce out, I could see someone had sprayed the the whole movement with oil or something,it was dripping with the stuff. f3a543ec6bba6264f362e2d6d8ff59e9.jpgI removed the dial & placed it in a shot glass full of l&r extra fine watch cleaner. Left it for 10mins whilst dabbing the dirt spots & diamonds with an ear buddy, after a few more swills round I removed it & placed in watch rinse for a further 10 mins whilst doing shaking motion to adgetate any remaining dirt & finally a good rinse under the tap. A quick blast with the air gun & dial complete. Next, was the case. 1dff53e5be1f840d3540e7123417ea3d.jpgluckily it was a gold filled job, so a quick buff on the machine & a bit if autosol to finish. The case came up like new(well alot better anyway).
Next the movement. Complete disassemble & clean. 3bc539592abe24db9e91cefc53bac012.jpg16e87c4e3f6e09faa3bd1a4af63d2f44.jpgde2f87d33e463bbf496127bcd9960d20.jpg5889a1cecc62bf744faf471472f25497.jpgbd67636c6ddb0148cafbd59c0ec98627.jpg537a96f6fc43a81a1ec4732e1aca5523.jpg1751eae311dd7bcb154d620d6b49ce04.jpg3b170d5def14a7855cd2a3263579b786.jpg37f331cfdbd32dd94a2754964e3ad1e2.jpgfae0111d7ce0faf654bb48be9bc4a053.jpg5cacd68165e595ae4cb5291c08ffbc31.jpgb3324fe66a065e2e18bcacdd00cac05e.jpg353660d5d9051527b7ef533cdd5b7f51.jpg24e20ff20fac01bf85cb759f2cc349f2.jpgfinally the rebuild. This was quite a challenge as I didn't really have a starting point. I started with the mainspring & train bridge. It was after about an hour in I realised I should of started with the keyless as the screw that holds the stem in place is located slightly under the train bridge. However, it's a learning curve. After assembly, I put it on the timegraph, managed to get it in beat & regulated perfectly. Slight concern with the amplitude as I thought it would be higher933a9f169209ff3df1c4e8e59121d1ae.jpg however I proudly present my finished watch 170248579885447f28e2f62177cf4cd7.jpghttp://images.tapatalk-cdn.com/15/08/16/1b5d26f16bc7d24daa11add604ad8119.jpghttp://images.tapatalk-cdn.com/15/08/16/dc1353432ea983734fb9157a0342e27e.jpg
http://images.tapatalk-cdn.com/15/08/16/1242ae43d68b10979b6e53883a7ac9dd.jpghttp://images.tapatalk-cdn.com/15/08/16/e2c4cbdd7167588163004835a31481a6.jpg
Your thoughts would be very welcome.
Sent from my GT-I9505 using Tapatalk
Edited by DJT2
Fantastic! That is definitely a win.
Nicely done, excellent result.
Thanks guys for your kind words.
Cracking job, you should be well pleased. You've ended up with something a bit special for no money!
High praise indeed, Thanks Geo.
I only have one question. The day jumper spring! 3fccc12c8c0b574b6964d828f746d635.jpgshould the screw holding it in place be tight? I've just noticed while changing the date that the day wheel moves intermittently. I tried it tight & the day wheel wouldn't seat properly, so slackened it off & wheel seemed OK. Now after playing with it the date changes great & crisp, but the day seems like something is not right.
I'm not familiar with this movement, but I would have thought the screw would be tight end properly when everything is aligned properly. I hope someone can chip in with some positive advice for you.
Thanks again guys for your kind words of encouragement. I can't believe I've just learnt something new which was puzzling me. The Crown would not go all the way in (stuck out maybe 2mm) I assumed that the previous owner had changed the stem & that's were his problems had started. However, this ties in with my day change issue. The Crown sticking out acts as a push button for quickset date feature. Thankgod I didn't chop the stem, that was going to be my next job lol [emoji1]
Great job done,nice watch. As a matter of interest as it has an unusual quick date setting function ie the crown is a bit proud has the crown stem got a seal to keep it water resistant.
Thanks for the compliment & I must admit, I've started to wonder about this myself. It may account for the movement being soaked with what I assumed was lubricant. But no I didn't see any seal on the case, stem or crown. Also, there was no gasket on the caseback.
Found this PDF if it helps however no mention of seals etc.
AS 1920.pdf.pdf
Thanks for taking the time to look, I'd already downloaded that from cousins & your right. No mention of seals. I'm going to have a look at the stem this weekend to see if it's obvious that there should be a seal.
attachicon.gifAS 1920.pdf.pdf
Very nice watch !!! You did quite an amazing job ! Enjoy it (or put at least $500 in your pocket ;) ) !
Thankyou Frenchie, I've decided to keep it, as it has now become the first of what I hope to be many of my 36000 vph fetish.
Excellent work! I hope to be that proficient one day!
Nice!
Your too kind Gary. I think I was lucky getting a good example to begin with. OK it was a none runner, but it was just the hack/keyless. I started at 10am & finished at 8pm lol. Not exactly a fast worker
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
