Omega caliber 601 problem.
By watchweasol · Posted
I use brake cleaner for cleaning. And once dried rinse in IPA works ok for me. Five litres of break3 cleaner, readily available is around £15 got to keep it air tight though. -
Bad news: Longines doesn't provide this service free of charge any longer. I have to ask for an extract from the archives or a certificate of authenticity, but I'm afraid it's not worth the cost for this watch. Too bad 🥴
Tool for removing or pressing the bezel? Most likely you have to remove the bezel (with a knife) before removing old crystal or inserting a new one. You can press the bezel with the crystal press if you have a suitable die with straight walls or otherwise a die that has enough clearance that it doesn't touch the crystal when pressing the bezel.
This will be my first crystal replacement, I have a press, but looking at the watch I wonder if I might need a bezel tool also. Any and all help appreciated.
