Hello,
I am on the hunt for a new setting lever spring for a (new to me) Ricoh 2338 from an Auto Just. I'm guessing the setting lever spring from a 2337 will also work but am not sure. I also discovered that the plate under the rotor bearing (I'm sorry that I don't know the correct term for this part) is cracked and need to figure out a replacement or way to fix it.
Thus far I've been unable to find leads on parts for this movement at all so any help or guidance would be greatly appreciated.
Attached is a picture of the broken spring (with the snapped part in blue) and the underside of the rotor.
