After trolling eBay UK for 36000 bph watches & particularly looking for the titoni cosmo 99 as it has the eta 2832 movement. I was having no luck what so ever. Then I remembered reading in someone's post within this forum about using other eBay countries. So I tried the refine my search & selected other countries. Unfortunately, still no luck. Then I decided as my last effort to try eBay.com & hey presto. I found 2, contacted the seller in India & he was more than happy to ship to the UK. He altered his listing to accommodate this & bam. £109 Inc shipping. Can't wait to receive it & get to work on servicing. 915400b94d7fc98cf7ad985509f8c475.jpg
Sent from my GT-I9505 using Tapatalk
You'll need moebius 941 for the pallet stones.
Since your interest is specific to the 36,000bph watches, you probably know this already but just in case you don't.............. :thumbsu:
Anilv
Anilv
Hi anilv, I'm using moebius 9415 for pallets stones. Is this the same?
9415 is recommended as it is thicker and is reported to stay in place. The concern with 941 is that being lighter it is more likely to be flung of the escape wheel/pallet fork as the escape wheel spins faster.
Personally I don't have this and have used 941 in the past...the reason I brought this up is if you're collecting these 36,000bph watches you should know this.
There was one time I was given a Grand Seiko hi-beat movement to service. When I told the owner I would not be using the correct oil on the pallet-stones he sourced it himself and I used that. He wanted to leave it (the oil not the watch!) with me but that wouldn't have been right. The Seiko was surprising in that it looked like your usual Seiko 6119 but with 21jewels and micro-regulator. He paid the equivalent of a Rolex 6694 at the time... case was pretty scratched-up but at least the gold medallion was still on.
Anil
Anil
Thanks for the info Anil.  On the subject of Hi-beats looking like run of the mill movements, I've been doing some research on this & it's got me pondering. (This info is from a posting on watchuseek regarding eta  36000bph movements)
Re: ETA 36,000 Hi Beat Movements:
2819 - 36,000 bph version of the 2801
2806 - 36,000 bph version of the 2804
2817 - 36,000 bph version of the 2816 (a day/date 2801)
2839 - 36,000 bph version of the 2821 (dateless automatic)
2826 - 36,000 bph version of the 2824
2837 - 36,000 bph version of the 2836
2838 - 36,000 bph version of the 2834
All hand fitting and dimensions are the same between the 28,800 and 36,000 bph versions.
Further, all parts, except the second wheel (#227), escape wheel (#705), balance assembly (# 721) and hack lever (#9433) are common between the 28,800 and 36,000 bph versions. (Even the mainsprings, a fact borne out by the Bestfit catalog.)
There were a number of movements in that family, including a number of 21,600 bph versions: (most of the repeated calibers for the same functions are different mainplate sizes, 11-1/2''' and 13'''
2800 - 21,600 bph version of the 2801
2802 - 21,600 bph versions of the 2804
2803 - 21,600 bph versions of the 2804, 13'''
2808 - 21,600 bph version of the 2816
2809 - 21,600 bph version of the 2816, 13'''
2820 - 21,600 bph version of the 2821
2822 - 21,600 bph version of the 2824
2823 - 21,600 bph version of the 2824, 13'''
2828 - 21,600 bph version of the 2836
2829 - 21,600 bph version of the 2836, 13'''
2805 - a 28,800 bph date manual (same as 2804, 13''')
2807 - a 28,800 bph date manual (same as 2806, 13''')
2810 - a 28,800 bph day-date manual (same as 2816, differences unk)
2811 - a 28,800 bph day-date manual (same as 2816, 13''')
2812 - a 36,000 bph day-date manual (same as 2817, 13''')
2825 - a 28,8000 bph date automatic (same as 2824, 13''')
2827 - a 36,000 bph date automatic (same as 2826, 13''')
2830 - a 28,800 bph day-date automatic (same as 2836, differences unk)
2831 - a 28,800 bph day-date automatic (same as 2836, 13''')
2832 - a 36,000 bph day-date automatic (same as 2837, differences unk)
I've highlighted the text in red that has got me thinking. Would it be possible to make a hybrid of a 2836 movement running at 36000bph.
Should be possible..watch out if the jewel count is different...escape wheels with cap jewels have different pivot ends.
I believe the pallet fork is different as well.
Anil
To add ... I read online someone had posted a problem with a chronograph running fast...this was traced to an incorrect 2nd wheel from a movement with different frequency. So parts can be interchanged... but you'll create hell for future watchsmiths..!
Anil
