On my timing machine I'm getting this reading does anyone knows what's the issue do a just sort the beat error out or is it something else?
Edited by Murks
I would suspect that the timegrapher can’t lock onto the escapement noise pulses. If the watch is cased try the crown up against the metal bar on the microphone.
Tom
It would be helpful out more information on the watch itself and a really nice picture of the balance wheel in the watch so we can see things
then classically of the timing machine if you have a snow globe effect or random dots until you get something that resembles lines all the rest the numbers are worthless. The timing machine is desperately trying to interpret basically garbage on the screen and it's giving you garbage numbers.
