What a disaster of a weekend!
Strike 1) Finished working on a quartz Rotary, polished up the case, new crystal. Battery arrived via Amazon.... What could go wrong??? Thing just wouldn't work.......
Strike 2) worked on a Sekonda, all going well, but rate was crazy high... Cleaned the balance, demagnatized...etc...turned the adjustment as low as it could go....still >+300 s/day, put to one side while I wait for inspiration!
Strike 3) have a beautiful Tissot with a blue dial, serviced the movement and looking great. Was a front loader so installed the new crystal after the watch/dial/hans installed....crystal jumps out and huge gouge out of that dial, about 1cm long down to bare metal...wife comes to find out why I'm having a tantrum in the floor like a 3 year old at Tesco.
Hopefully that's all my bad luck used up for September... Hopefully
  • Sad 3
Sorry Waggy- sometimes bad news comes in threes. Hopefully you’ve got them all out of the way now…
…my weekend wasn’t so bad. I had a stud screw escape the balance cock in the wash. I’ve been meaning to have spares on hand so cousins in all their efficiency dispatched the pocket watch stud screws what made it to my cart by mistake. Second time’s the charm…
…setting that one aside I decided to open up a non- runner, hoping to see a high end ETA inside…
..good news is I think I saw where Mark has lovely video servicing one of these. Despite his ā€˜don’t try this at home’ disclaimer I may give it a go…
    • Hi Mike I did a ships clock a long while ago, not a Hermle though and without getting the beast in my hands to refresh my memory I can’t recall the timing. Ā This doesn’t help I know but will start the grey matter turning.
    • I have stripped and cleaned a Hermle ships clock. It was just oily, no major faults, and I reassembled it, following my photos in reverse order. The time train is fine but the strike train will not play the ships bell strike for half-past. Ships bells play a four hour sequence for the 'watches' and play double 'ding' for the hour and the double dings plus one for the half past (eg half past the second hour is 'ding-ding' 'ding-ding' 'ding'). Sounds complicated but it isn't really. The strike wheel consists of pairs of bumps (for the ding-ding) and no single bumps. There must me some mechanism on the half-past that lifts the strike lever over one of the bumps so only one ding is played. When I get to a half past, it still plays double ding. I have a feeling it is to do with the lever in front of the rack (there is a sprung attachmentĀ  on it) and the position of the wheel (to the right) with the two pins that lets that lever fall, but no matter where I place that wheel I cannot get a single ding at half past! Please can someone help with advice on positioning so I can fix this? BTW Happy Easter 🐣
    • I think it would rather be the blast of high current drain that would do the damage. But if used occasionally to maybe fix a mainspring or do dial feet it might be worth trying especially if the mainspring or a replacement couldn’t be found.Ā  Ā  Tom
