To bush or not to bush?
Rixy
I have taken apart an old 1930s Bentima Westminster chimes clock and it looks like it was rebushed in the past but some are a bit iffy (not quite dead-on), some are developing oval holes and one has clearly been reshaped by being hit a few times with a punch. I have attached a few photos, sorry they are not that clear - it's the best my phone can do. I think the plates probably need rebushing but I have yet to try doing this.
Can it be done by amateurs? What equipment should I get? I have seen people cut their own bushings on a lathe (I do not have a lathe) but I see that pre-cut ones are also available from Cousins.
As ever, all advice gratefully received. 20230907_202721.thumb.jpg.9b04fb3646492a504bc0d999c59b62d5.jpg20230907_202740.thumb.jpg.deace260edfee588f80f04823221e881.jpg20230907_202711.thumb.jpg.d241af5e91bb130d51b0c39a29cf7f3d.jpg20230907_203001.thumb.jpg.607d745e3bf6de08f9310b401b276a7d.jpg20230907_203023.thumb.jpg.ed9f9367f1e86d949cb4a2b5feeb0efa.jpg16941156463796750672155964830262.thumb.jpg.81c275ec3cedc416cc7e52b34e347e6d.jpg
The thing is, you never know if the last clockmaker bushed these properly, or if they are in the correct position.
Let's assume they have been done properly and have worn oval, then it would be a good idea to press them out and new ones pressed back in place.
If the position of the bush is questionable then you have a bit of a headache on your hands, as I assume you don't have a clock reaming and bushing tool.
If you don't have the correct tool to sort this out, I wouldn't attempt it, as it is only going to go pear-shaped on you very quickly if you haven't done this before with the correct tools.
Hi as Jon said are the bushings correct ?  To find out you will need to dismantle the clock and check the intermeshing between the two interrelated wheels for tight spots or bad mesh bearing in mind some are already worn. If they all check out you can press out the bushes and fit new ones and broach to fit the pivots.  Bushing can be done quite easily by hand, you don’t need £1,500 pounds worth of Bushing machine. Always cut the hole undersize and broach to fit the bush ( friction fit) then broach the bush  to the pivot. When the wheel is inserted to the bush there should be no more than 5% side motion from vertical. Always fit a bush from the inside of the plate, I use a bench drill with a punch inserted to press the bush home . Once fitted and cleaned up cut the oil sink carefully and the bush should be invisible.  It isn’t rocket science it just requires application and care.
I think you meant 5 degrees from vertical, not 5%. Good advice was given though!
31 minutes ago, Rixy said:
Thanks Jon. I might put it to one side until I get more experience and have time to start an horology course.
If you live near South London, I run small classes of six for watchmaking courses. Check out my website: https://www.jonthewatch.co.uk/
If you are interested in clockmaking courses, check out EFHC in Essex where I used to teach until July this year: https://efhc.org.uk/wordpress/
Edited by Jon
Thanks Jon. I am interested in clockmaking (are you watchmaking only?) and was considering the place in Essex. Am quite busy at work at the moment but will have more time for this in about 12 months.
Hi Watchweasol, I have a broken 1960s Smiths movement that I have salvaged bits from. I might have a practice rebushing that - it won't matter if I mess up!
To press out a bushing, what do uou use to press out the old ones?
I'm a watchmaker, so Essex is the way forward.
You would use a clock bushing/reaming/pressing tool. You could do it with a watchmaker staking set, or even with small hand punches, although when pressing them back in you have to get the correct end-shake. You could use a watchmakers jewelling tool, as you have a micrometer setting to get the depth of the bush perfect.
Edited by Jon
Hi. To press out the old bushes I would use the same method as putting them in. As I don’t own a Bergeron tool I would use a small diameter punch in the drill press over a holed plate or a big nut. The watch makers staking set, of which I have two I feel are a little delicate for that type of work and may get damaged.  There are clockmakers sets which are a bit more robust. As to setting end shake the bush needs to be flush with the inside of the plate only and is not as critical as in watches.
If you have an old movement all the better to practise with. Hand broaching and drilling out worn holes Just takes care, there is plenty of guidance notes etc on the net to look at.
Tap out all those bushings. As you are just starting out buy a box of Bergeon Number 4166 this will cover most of what you will need. A set of clock bushing Broaches get the best you can afford if you can afford get  Bergeon they will always keep there cutting edge. German ones are also very good. A good set will last a life time. There is no reason why you shouldn't be able to handle this. There are some videos on this on youtube.
Thanks everyone. Had a look on Cousin's site. A box of Bergeon 4166 is around £77, is that about right? Have seen a set of Bergeon broaches too that I can get. Need to get a drill press and some punches too so might wait until pay day!
I think I said I use a bench drill as a press. It’s a tool which if you have is usefull for the job, it is an option only if you have one to hand, just as you don’t need Bergeron broaches or Bergeron tools to do the job there are many watch tool makers do Broaches. I got mine from Melvyn Passmore when he was in business and they are good as were his other tools .
That sounds like a great idea the drill press without plugging it in, like a large jewelling tool with the addition of a revolving sprindle. I have just the thing.
Any car boots near you ? I often see drill presses for around 20 -30 quid, they dont even need to work electrically if you are just using it as a press, they usually have a depth stop.
Good idea. 👍 I hadn't thought of checking them out. I'll see what's coming up. Thanks.
This one was a fiver inc. a half decent electric power drill. It won't have quite the same application as the purpose made pillar drill as there is no stop , but it gives you an idea what you can pick up for very little. I talk to the regular sellers when i go and they all say how hard it is to sell at the moment, its definitely a carboot buyers market. But folk having old parent's garage clearouts nearly give stuff away, just to dispose of stuff without actually disposing of it. If you pick something up its always nice and interesting how well you've done.
I have always used watch staking tools, with a small hammer, the bush should be a third way in the hole so it doesn't take much to hammer home. Pivots should be looked at for signs of wear and roughness, tidy up by removing marks this is done by using needle files, a small Arkansas stone, emery sticks then finally burnish them all.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
