CAN ANYONE ADVISE ME ON HOW TO REPAIR THIS OR POINT ME IN THE RIGHT DIRECTION OF A REPAIR SHOP, THE WINDER HAS COME AWAY FROM THE MAIN BODY AS PER THE ATTACHED PICTURE, IS IT A MAJOR ISSUE, I DO NOT WANT TO POST THE WATCH ,,
2 minutes ago, Nucejoe said:
Loose/ worn  set lever screw or worn stem, back plate might need to be removed.
Welcome to the WRT forum.
I asked if it was new to him because I wondered if someone had worked on it and not tightened the set lever screw.
Usually on this discussion group people do an introduction so we have a little background information on your knowledge of watch repair. Typically if this was a real Rolex watch this isn't supposed to happen. Then can you fix it yourself possibly you'll need some tools and if you have an accident ill be very very expensive if it's real. Or we could point you in the direction of a shop but we don't know where you live on the planet?
Where was the watch purchased at what's its background history?
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
