The question is what is genuine?  Cartier is essentially known for designing and making jewellery so Cartier didn't make the movement. Cartier cases have serial numbers, there is no serial number so they didn't make the case, and their cases are held together by screws. If they employed another company to make the case , did someone else also make the dial. At best Cartier commissioned someone to make it, so its not really Cartier. There are a few examples on ebay the same as this, not sure if we can use that as evidence for it not to be fake unless we are suggesting only one fake has been made. Surely the Cartier tank is in the top list for most copied and faked watch of all time. Understandably i cant figure out why a world renowned Jeweller would put their name to this.
After a little research it seems it was the eventual selling off of the 3 branches of Cartier in the late 60s through to the  70s that initiated the cheaper models coming through. The idea of the Must de Cartier maybe something in the name that everyone must own one. Previous to this the vermeil , gold plated on silver which our example is clearly not by the worn lugs.  Its easier to fake a cheaper watch, counterfeiting in the 70's was now able to explode on this Brand.
This is a friendly site, every one pitches in and helps each other.  The advanced members must sometimes roll their eyes at the questions we amateurs ask but they do their best.
I have not come across such a arrogant member as yourself on here before and hopefully I won't do again.
With respect - I seek only to guide the OP with my prior knowledge of the brand.
That remains my aim - despite somewhat supercilious tangents within the thread.
Come on members please keep it friendly.  We all try to help. Just think before you start typing.
For what its worth I still say it is a fake the engraving on the back of the case is very amateurish a single word has different size lettering.
13 hours ago, 316lad said:
Still a bit of a rubbish movement though - ETA by this time.
Sorry to repeat my question @316lad, but I'm really curious if you could elaborate on why you describe the movement as "a bit of rubbish".
My main interest in watches is precisely their movements and so far I have a somewhat limited experience of the ETA movements and that is why I am so curious.
Thanks! 👍
Thanks! 👍
My comments pertain to the aesthetics - not the trusty mechanical engineering of the works.
Interestingly - the OP's ebay watch sold for $304 - which seems reasonable considering the large amount of work that looks required to bring it to market for the demographic.
Well, beauty is in the eye of the beholder. So you are of course entitled to your personal opinion. If may ask, what exactly in its aesthetics do you perceive to be "rubbish"? Is it the look and layout of the various bridges, wheels, screws, etc., or perhaps the way it was decorated or something else? Sorry to be going on about it, but as I said, it got me curious.
8 hours ago, oldhippy said:
The decoration is called Guilloché.
Yep, with that particular finish called Tapisserie.
AP take the medal for that particular finish.
Edited by 316lad
  • Similar Content
    • Same question that was asked last time Hakan, and emphasis was placed on it. It was ignored. The thread should still be there, if not I have a copy of his reply.
    • This is probably the single most important point. One of my best friends, 48 years old at the time, suffered a massive stroke about 15 years ago. He barely survived, but his life was never the same after that. If you had asked me back then to guess which of my friends might have a stroke and nearly die, he would have been the very last one I'd have picked. He was perfectly healthy, played tennis three times a week, ran a successful business, was full of life, and had a wonderful wife and well-behaved teenage kids. The harsh truth is, we never know when it’s "game over." @Mark, I truly wish you a long, happy, and successful life. But have you given any thought to some kind of backup plan for WRT in case the worst should happen? Is there anyone who could keep the site going? If you can reassure us in some way, it would mean more than a lot to us!
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
