Hello all! My name is Garrett and located in PA, USA. I've been into watches since I was a child and in my mid 20's (Currently 39) wanted to get into watch restoration and maintenance / repair. In the early 2000's, I decided to take a few online courses on servicing an eta 2801 as well as joined the NAWCC. I bought some basic watch tools as I was still in college and working as an intern, so money had priorities elsewhere. I was hooked, but turned off on the expense it was required to acquire the necessary tools. My backup plan while I was starting my career (IT / High Performance Computing) was to go to watch making school. Well 15+ years later my career took off for the best and I am now at a point in my life that I have income to spend money on good tools to get back into the hobby as I put off working on watches during that time to focus on other areas of my life and hobbies.
I have a pretty nice watch collection (to me) and also like to collect pocket watches. My admiration for pocket watches is due to the art, ingenuity, and craftsmanship that went into them. They are truly a beauty to be hold. My focus right now is to start learning on pocket watches to service and repair as needed and then move to the smaller watch movements. The past month or two, I have been slowly picking up tools with the hopes of starting to service my first pocket watch (Waltham Model 1892 Appleton Tracey 17j) that was from my grandparents after they had passed. Before I start work on that, I will be practicing on a few cheap seagull st3600 movements.
I apologize for the rambling, but in the end, just wanted to say hi and hope to be an active member of the forum (even if it is just lirking). I have been a huge fan of Mark Lovic's youtube channel for many years and plan on signing up for his courses.
- Garrett
Some quick and dirty shots of my current collection.
From Left to Right:
Waltham Appleton Tracey Model 1897 that was inherited from my grandparents. Needs to be serviced and restored.
Hamilton 992B
Bottom three were recently acquired and will be serviced as well when I get the courage.
Hamilton 992 16s 21j in salesman dase
Illinois Bunn Special 16s 21j in salesman case
Elgin Father Time 16s 21j in salesman case
As you can see, my area of collection is focused on salesman case watches. Which I have always been fascinated by and love to be able to look at the craftsmanship of the movements.
My watch collection:
Frome left to rignt:
Omega Speedmaster Professional
Omega Seamaster Planet Ocean
Stowa Antea Klassik
Longines Master Collection
Damasko DC56
Christopher Ward C9 Moonphase
Christopher Ward C8 Power Reserve
Christopher Ward C9 Harrison 5-Day
From left to right:
Bulova Lunar Pilot
Archemede Pilot 42
Seagull Nomor / Stowa homage
Hamilton Khaki King
Luminox
Invicta Diver - ETA 2824
Unmarked watch built using ETA2801 when I did my watch course some years ago using parts from Ofei, etc
Davosa with Unitas 6497
Citizen Nighthawk
- Garrett
Edited by garrettwp
From Left to Right:
Hamilton 992B
Stowa Antea Klassik
Damasko DC56
From left to right:
Bulova Lunar Pilot
Archemede Pilot 42
Hamilton Khaki King
Luminox
Citizen Nighthawk
- Garrett
Nice collection you have there, especially those pocket watches. I see you have some Christopher Ward watches. I'm currently in talks with them to produce a detailed service manual and a set of lessons to teach to their watchmakers for their in-house movement, The SH21 twin barrel that they put in the C60 Abyss. Where can you get an in-house movement in a watch for less than £2500? I'll tell you... Know where!
I was told by their head watchmaker, that when servicing the C9 Moonphase, the moon part breaks 50% of the time as it is so fragile.
Are they working on the moon phase to make it less fragile ?
No, as it is cheaper to replace the broken ones rather than the development and production of new ones that won't break. The way of the world, I'm afraid.
A newbie and you're making us jealous, hehe.  Nice collection.
Thank you all. I've worked hard to own what I have and appreciate every moment of it. For the pocket watches, I hope to own more to the collection, want to keep the history going with such beautiful timepieces. I hope my son can appreciate them as much as I do some day.
I hope the C9 will hold up, I do not wear it often, but have always been a fan of moonphase and complicated calendar movements. I do like the new Moonglow version that Christopher Ward has out.
    • Tool for removing or pressing the bezel? Most likely you have to remove the bezel (with a knife) before removing old crystal or inserting a new one. You can press the bezel with the crystal press if you have a suitable die with straight walls or otherwise a die that has enough clearance that it doesn't touch the crystal when pressing the bezel.
    • This will be my first crystal replacement, I have a press, but looking at the watch I wonder if I might need a bezel tool also. Any and all help appreciated.
    • I'm not entirely sure you fully understand what he's doing in the video. For one thing he's giving examples of things like about 16 minutes he talks about opening up the regulator just a little bit. Opening up the regulator slows the watch down to compensate for that he moves the regulator fast and now it's keeping time again but the regulator pins are too far apart. I have an image down below on top of it shows the effect of regulator pins and amplitude. If the regulator pins are farther apart than the example down below then at a higher amplitude timekeeping will be much worse. Why the regulator pins are supposed to be adjusted as an average rule approximately twice the thickness of the mainspring itself. In other words if you look at the spacing it have one half of the hairspring thickness on either side of the hairspring itself. There is like he talks about the video a little bit of adjustment here and there. So in his example where he opened them up it will really dramatically screw up timekeeping based on amplitude. Then when you get to the 20 some minutes like you say he is adjusting the regulator pins closer together to get a more even timekeeping based on amplitude and amplitude changes are caused by going to various positions. Then and the other example of the image down below regulator pins too far apart and they hairspring is not centered and look what that does the timekeeping. So hairspring is supposed to be centered regulator pins are supposed to properly spaced. Then you get reasonably even timekeeping like it shows in the upper image. It's not like we're regulating out positional errors like poising errors because that's something entirely different.   In the part number above and in the video both of you left off details. I which version of either of your watches I will just make you's timing specifications for your watch down below may specify how you're supposed to do it other words you wind up the watch fully wound up you wait 10 to 60 minutes in the four positions it should be within 60 seconds. Yes it can be closer but you may not actually get zero.     Now let's compare with the 2892 and see where we might have a discrepancy. First off we have a problem of which one is a using did he use the chronometer grade 1 or the top grade or what?  None is basically just much tighter timing tolerances. So when he's using an example watch conceivably might be a chronometer grade watch then things are going to be much more  perfect than what you're going to see.       NH35_TG.pdf ETA 2892-A2 Manufacturing info.pdf
    • Note the 8992 is 850 pounds for a liter. I think this is really for industrial settings like they say, where it would be used as a final bath in a 20,000 buck cleaning machine. I use the 8981.   That is excellent- I don't often get to see a serviced watch 5 years later, but when I do I expect to see pretty much the same oiling on the balance jewels as when it went out. I think at that area, being essentially sealed, it really should remain fairly pristine for likely 10 years. It's why some makers go to the trouble to use cap jewels on the escape wheel as well- not so much for friction reduction, but to keep the oil longer where it really counts.
