200 year old Chronometer clock pendulum
KSB
This clock is a John Stokell, NY made in 1832. The pendulum is a lead crystal container with mercury in it. The mercury comes out the top even though it looks sealed. What are my options? Can I get it resealed? And who does that? I am in the Dallas/Fort Worth TX area. Thanks!
As a retired dentist, I'm very familiar with mercury.
Can you actually see droplets of mercury around the pendulum? If you can, sprinkle sulphur powder over it, open all doors and windows and let it stand overnight.  Then use a small brush and carefully clean up the area.
Mercury is toxic. Just one small droplet is enough to saturate the air in an enclosed room. I moved away from using dental mercury in my practice more than twenty years ago. But there are some situations where amalgam is the only material suitable for the restoration. Hence I had to keep a small supply of it. I used to store my mercury in Tupperware containers in a drawer at my clinic. And after some time, the edges of the drawer would develop a strange grey stain. It can be cleaned off with some effort but it kept coming back. I suspect the stain is caused by mercury vapors.
A study showed that dental staff have a higher level of mercury in hair and nail samples when compared with the general public.
A friend of mine sent me an amalgam mixing machine (amalgamator) for repair many years back. When I opened up the machine, there was a puddle of mercury inside. I quickly closed it back and disposed of the machine. I quickly informed my friend and she went for a hair and nail sample test for mercury. It was found that she had seven times the safe limit of mercury in her body!
But the good news is; she's still alive and appears fine. 🤣
Recently, a nice crystal regulator clock came up for auction on eBay. I was really tempted but after much deliberation, I decided I wasn't going to have mercury in my house.
I've heard of people converting their mercury pendulums to gallium, which is safer. Or maybe we just don't know enough about gallium toxicity. 🤪
Gallium looks a lot like mercury, except it's solid at room temperature. It has a melting point of about 30°C. A piece of gallium would melt and look like mercury if held in the palms of your hand. And now with global warming, where temperatures above 30°C are getting common, gallium looks like a real viable replacement for the mercury in crystal regulators.
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
